  • 1994 - 1995 Specific Tech
Gauges?
  • Thread starter Thread starter 1995 vibrantred
  • Start date Start date Dec 27, 2004
1995 vibrantred
Ky
Dec 27, 2004
  • Dec 27, 2004
I would like to put 2 Auto Meter gauges in my 95, but dont Know what to put in it.
I would like some thing useful, and easy to install. And dont have to buy alot of stuff to put them in.
Electric or mechanical? and need 2 gauges?
stprorolla49
1,455
15
39
Fairfield, CT/North Jersey
Dec 27, 2004
  • Dec 27, 2004
get a water temp and oil pressure..........both electric...easy to install and put em in a pillar pod.....125 bucks total......just bought Sport Comps from Jegs last nite..........
smokediver27
203
Florida
Dec 27, 2004
  • Dec 27, 2004
I went with the Lunar series voltmeter and water temp on a pillar pod, very happy with them thus far.
blksn955.o
3,263
st.louis mo 314
Dec 27, 2004
  • Dec 27, 2004
I have a 2 5/8 pro comp liquid filled fuel press. guage on my cowl
I also have a double A-piller pod that I plan on putting an elec. water guage, and n2o guage in. I hope to order the guages next week.
1995 vibrantred
Ky
Dec 28, 2004
  • Dec 28, 2004
gauges
The mustang hads a Temp gauge, ( don't know if it is water temp is it?), and a oil gauge,(don't know if it is oil press or oil temp?. I would like some thing that is not in the car, stock. So tell me what the oil and temp gauges are, in the car stock?
any one useing a trans temp gauge
HISSIN50
34
129
Dec 28, 2004
  • Dec 28, 2004
agreed. though i am a fan of mechanical gauges (not so much for accuracy - in this day and age, electric guages are pretty accurate, but rather for the 270* sweep), this suggestion will be easy to plumb and install. those two gauges should be the first two gauges to be installed, IMHO.
also, some electric gauges offer 270* sweep now - in case you like that.
good luck.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Dec 28, 2004
  • Dec 28, 2004
explain that "sweep" stuff...i never knew what it meant when i looked at guages in the mags.
1995 vibrantred
Ky
Dec 28, 2004
  • Dec 28, 2004
I am looking at Auto Meter water temp 100-250, and oil press 0-100 psi, any good?
HISSIN50
34
129
Dec 28, 2004
  • Dec 28, 2004
most mechanical gauges have a range of ~270 degrees from 0 to Max. many electric gauges have something acute (like 90* or less), which just makes it harder to interpolate, IMHO. i like the wider spread in the calibration (with a mechanical gauge, one can read the measurement almost to the exact increment, whereas with electric gauges, the needle width often covers 5-10 increment's worth).
wow that made no sense at all. you get what i mean?
HISSIN50
34
129
Dec 28, 2004
#10
  • Dec 28, 2004
  • #10
any of the AM products should treat you well. those two gauges should give you the ranges you will need. really comes down to what you like, what fits and what works with your interior and gauge scheme.
good luck.
E
EpiKk3
405
#11
  • Dec 28, 2004
  • #11
how do you wire up new gauges through the pillar without wires hangin out
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Dec 28, 2004
#12
  • Dec 28, 2004
  • #12
yea i gotcha...makes perfect sense
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Dec 28, 2004
#13
  • Dec 28, 2004
  • #13
Water and Oil are fine. When you wire them, the A pod hides them until they exit out near the dash. At that point, then can go down behind the driver's kick panel.
RC
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Monday at 5:18 AM
manicmechanic007
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
