Gear install info
  • Thread starter Thread starter rd
  • Start date Start date Sep 12, 2004
rd
3,316
63
109
Ocean Springs MS
Sep 12, 2004
  • Sep 12, 2004
Does anyone have directions for an 8.8 gear change, or a link to one. Hopefully from a Ford manual, with the torques and preload info. Got 4.56's waitin' in the garage.
My book is on loan to someone for an aod install.
Thanks.
M
mooktank
237
  • Sep 12, 2004
4.56s?!?!?!
holy flkwflk!
Well anyways, take off your rear cover
pull take off your wheels/drums
take out c-clips by pushing in axle shafts
take out the shafts, pinion pin and s-spring.
Take off carrier bearing caps making sure you dont mix them up.
Pull out the carrier
pop the ring gear off.
Put the new ring gear on after cleaning it.
Make a tool to hold pinion yoke in place while loosening pinion nut. (i drilled 2 holes in a piece of flat stock steel and bolted it on.)
pull out pinion.
well i have to go now that should get you started ill come back later and finish hopefully.
M
mooktank
237
  • Sep 12, 2004
oh yeah and always remember to not be scared because like a ford technician once told me "Theyre just big meat grinders" haha.
rd
3,316
63
109
Ocean Springs MS
Sep 12, 2004
  • Sep 12, 2004
Thanks, I found the motherlode on the Corral site. About 16 pages.
Yes 4.56, only because I don't dare run the motor over 6k.
When I fix that problem, I will step it up. Makes it easier to get up the ramps onto the trailer.
stockhatch
536
polar sloth country
Sep 12, 2004
  • Sep 12, 2004
http://www.corral.net/tech/drivetrain/gears.html
AC
EDIT: oops, a little slow on that one
SlowGT
826
Columbia Co, PA
Sep 12, 2004
  • Sep 12, 2004
I may have missed it in that right up, but I'm going to mention it anyway. Just as you keep track of the carrier caps, also keep track of which side the carrier shims came from. If all of your pre-disassembly measurements were in spec, you'll probably be reusing the factory shims for the carrier and the pinion. Good luck.
M
mooktank
237
  • Sep 12, 2004
yeah i used all factory shims on mine. Just check your contact pattern with marking compound and make sure youre right in the center of the tooth. Grab your dial indicator and set the backlash to spec by moving the carrier side to side with shims.
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Thursday at 7:46 PM
JMG9350
J
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
  • dan50
  • Jul 18, 2026
dan50
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
