gear oil
hookups333
154
Jax Florida
I am about to rebuild my trak lok i just bought the kit from steeda today. I plan on adding the clutch plate for more break away torque. I was wondering what type of oil should i use. I thought i remembered someone saying not to use friction modifier because it to make the clutches slip. Oh yeah I will be road racing the car so I need the rear end to stay cool and last as long as possible til i can get a new diff. thanks
Derek
You're right about the FM lowering the coefficient of friction (and many road racers omitting it).
I'd choose a nice synthetic and see how it does without FM (FM is easy to add but impossible to remove).
You'll note that with the synthetics, many of the lower weights (75W-90 etc) have FM in there already. But the heavier weights (85W-140 etc) often do not have FM. Considering the low temp characteristics of synthetic 85W-140 compared to dino 75W-90, the fact that you're going to road course the car and that later 8.8's came with synthetic 75-85W - 140, it might be worth trying out.
I tend to use Redline because the local speed shop sells it at a decent rate.
Good luck.
