gear ratios?
  • Thread starter Thread starter silvrbullit
  • Start date Start date Apr 29, 2007
silvrbullit
  • Apr 29, 2007
I've got a '65 coupe w/ a crate 302 w/ GT-40 cam and heads from Ford Racing and T-5 4-speed tranny, problem is ive got a "highway" gear ratio set and my low end isnt near wat it could be. So my question is wat ratio should i put in that will utillize all my horses out of the blocks but at the same time not have my rpms thru the roof wen im on the highway?
Pbum5
515
Minneapolis, MN
Apr 29, 2007
  • Apr 29, 2007
a T5 is a 5 seed tranny.
Did you mean a T-10 4 speed?
Bosscat
1,265
England
Apr 29, 2007
  • Apr 29, 2007
3.50 would be my choice. A good all around gear.
68EFIvert
639
Camas, Washington
Apr 30, 2007
  • Apr 30, 2007
I have a very setup and went with 3.70 gears. I thought it did a better job of getting the engine to the power band a cruising speed. Hopefully equates to not as much bogg if I smash the throttle in 5th gear.
65intex
85
Ft. Worth, Texas
Apr 30, 2007
  • Apr 30, 2007
I just changed out my gears not to long ago and went with 3.40's and posi. If I was to do it over again I would probably go with a 3.55.
SoCalCruising
2,437
SoCal
Apr 30, 2007
  • Apr 30, 2007
3.70s, for sure.
iskwezm
4,159
20
79
Rowland Heights,California
Apr 30, 2007
  • Apr 30, 2007
If its a 8", 3.80's. i have them and work good on the freeway and around town.
rbohm
6,698
550
204
tucson,az
Apr 30, 2007
  • Apr 30, 2007
this would also be my pick:SNSign:
SoCalCruising
2,437
SoCal
Apr 30, 2007
  • Apr 30, 2007
Yeah, it would be good to know if you have an 8" or 9" rearend.
302 coupe
1,952
Macon, Ga.
Apr 30, 2007
#10
  • Apr 30, 2007
  • #10
and 5 speed or 4 speed....
no need to limit yourself to 3.50's if you have OD, you can run as high as 4.30 and still cruise comfortably. If you have no OD, 3.50-ish will be about the max for easy cruising.
ultrastang
1,092
Arkansas
Apr 30, 2007
#11
  • Apr 30, 2007
  • #11
Maybe this will help give you an idea of what RPMs to expect at a highway speed of 60 MPH;
http://ultrastang.com/Rearinfo.asp?Page_ID=4
http://ultrastang.com/Rearinfo.asp?Page_ID=3
silvrbullit
#12
  • May 1, 2007
  • #12
thanks guys, sorry bout the typo w. the tranny
67-Coupe
N. Georgia
May 1, 2007
#13
  • May 1, 2007
  • #13
Do a search on gear ratios and you'll find several several threads on the subject. Here's my thread. http://forums.stangnet.com/showthread.php?t=693801
Attached you find a spreadsheet that'll help you select your gears.
David
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
H
1966 mustang starter and pulley troubles
  • Hotrods4ray
  • Sep 24, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
Realmongo
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
65 Coupe I6 Auto to 302 EFI 5 Speed Swap
  • Scuderia
  • Feb 3, 2025
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 9, 2025
