gears are hands down the best mod you can do with the reasonable chance of paying $300 for parts and install. I paid $200 parts and did it myself, with the advice of a good friend. It's a little overwhelming at first if you have never seen internals on a rear but dont fear the gear. Have a guide go step by step and keep it as simple as possible and be prepared to spend a while on the carrier shims if you're going with a steep gear, the pinion will not likely be too much trouble, and if it is, have an air chisel handy to remove the bearing if you dont have a seperator or a presss handy. It is more complicated than some seem to believe, but like I said, keep it simple (you're just trying to make two gears properly mesh) and you will be fine. 4-9 hours depending on experience and availability of tools.
