I seem to be having some issues i believe are coming from the rearend of my car.... a noice resembling a clunking in the rear while truning slowly(only when car is hot), and a vibration i believe to be associated with the rear. I have already replaced my u-joints and had the shaft rebalanced.
The vibration is less upon acceleration, but seems to worsen at cruising. light load applications. I was also thinking back, i have had a vibration for quite a while now. Even am starting to pinpoint it to shortly after the rear gears were installed. So i am thinking that the rear end is not set up right, and causing this harmonics type vibration........... Is this possible? I am pretty sure that i never had these vibration issues with the stock gears, and i have even driven a friends car with stock everything, just to see if the vibration i am thinking of has always kinda been there.... I know under acceleration, almost any t-5 with a shifter is gonna vibrate a little......
Please help me out with suggestions, i thought that the u-joints would cure all this.. Do you guys think it is possible for it to be coming from anywhere else..... i rule the D/S out due to the work that has been done to it. Would a new gear install with 3.73's and an alum. driveshaft cure all this..
jason
jason
