  • SN95 4.6L Mustang Tech
gears help
  • Thread starter Thread starter peepeeskillz
  • Start date Start date Dec 11, 2009
P
peepeeskillz
171
texas
Dec 11, 2009
  • Dec 11, 2009
im swapping in some 4.10s and im having trouble getting the carrier out, any one have any suggestions? ive taken out the differential locking shaft, c-clips, axles, and the main bearing caps, and the carrier wont budge any help would be much appreciated
Tim2002GT
635
Tulsa, Oklahoma
Dec 11, 2009
  • Dec 11, 2009
Sometimes they can be a mf'r to get out of there. What I ended up doing was using a 2 jaw puller to get it out. I put a 1" think prybar across the case and used that to set the puller on. Then hook the jaws on each side of the differential and wrench it out of there. Once you get it pulled out about 1/4-1/2" it will come out fairly easy.
R
rockyracoon
874
27
49
margate NJ
Dec 11, 2009
  • Dec 11, 2009
I have always used a prybar to pry between the housing and one of the ring gear bolts.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Dec 11, 2009
  • Dec 11, 2009
hold the carrier still with a large screwdriver through the hole that the center pin came out of and just rotate the pinion gear. it will push it right out for you
P
peepeeskillz
171
texas
Dec 11, 2009
  • Dec 11, 2009
thx for all the help guys! after i posted this i ended up sticking a pry bar through the middle of the housing on the bottom of the carrier and pryed straight up and it just slid right out lol. thx for the help
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
Cobra 8.8 differential rebuild shop question
  • Sestemybe
  • Aug 5, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 15, 2025
baileygruwell
9
1994 Mustang GT 5.0 L Convertible
  • 94ns95
  • Jun 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 19, 2026
94ns95
9
