Gears Install cost
  • Thread starter Thread starter tannerc91gt
  • Start date Start date Aug 14, 2009
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Aug 14, 2009
  • Aug 14, 2009
picking up some 4.10s for the 91 and am looking for a good shop to install them, theres a few mechanics around town im considering but whats a reasonable price to install the gears?
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Aug 14, 2009
  • Aug 14, 2009
my entire rear end in my other f250 was rebuilt not too long ago, and it was only 250, said that if i wanted new gears installed to do it then since i wouldnt cost anymore cause they had to tear everything apart anyhow
Rick 91GT
Mustang Master
95
99
PA
Aug 14, 2009
  • Aug 14, 2009
Yes if a full rebuild is being done the gear set is off or partially off so the cost is little...just time to properly set up the depth of the new gear set.
To have the Gears swapped you'll be in the $200-250 for labor, plus gears $179-$200 and I would supply them a "gear set-up kit" so you have all new bearings, etc.. $100. It's a good time to install new axle bearings and seals if you have any issues or leaks. I personally install and recommend the Motive or Pro5.0 gears (made by Motive), or the Ford Racing are my second choice.
I have found some other guys just swap in gears using the same shims that were in the stock housing, while this may work it is not the proper way to do them. The new gear set must be measured and set up all new, this will ensure a long, quiet rear for many years.
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Aug 14, 2009
  • Aug 14, 2009
250-300 is the normal going price ive found...
306notchback
62
Bells, Tx.
Aug 14, 2009
  • Aug 14, 2009
Paid $250 for mine, including the install kit!
1991notchbackLX
1,483
47
48
New York
Aug 14, 2009
  • Aug 14, 2009
I paid $500(ish) for new 3:73 gears, kit, and the install. That seems to be the going rate, at least here in NY.
rbonella
409
@ home
Aug 15, 2009
  • Aug 15, 2009
Like Rick91GT said, buy the gears and the install kit yourself to save a little $. I have never had a problem with FRPP gears. My last install was 3:73's a few years back. They charged me $400, but I also had them tighten up my posi pack while they were in there. Another expense to consider is the speedo gear. I think 4:10's are still able to calibrate with the speedo gear. That calibration cost me another $100 but having an accurate speedometer is huge! Having your gears properly installed is one thing you don't want to chince out on. Nothing worse than gear whine or an improper install. Find a professional, and pay to have it done right! If you have 2:73's or even 3:08's, you will LOVE your 4:10's!
tannerc91gt
2,967
234
Indiana
Aug 15, 2009
  • Aug 15, 2009
I've got 2.73s in it now so I'm hoping 4.10s will wake it up a bit
rbonella
409
@ home
Aug 15, 2009
  • Aug 15, 2009
Night and day difference. You'll be pleasantly surprised for sure, don't be surprised when your back tires are bald though. my first gear change was in my 88 coupe, 2:73's to 4:10's, when i picked the car up, I could believe the difference it had made. 2nd gear pulled like first gear used to!
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
Rear diff rebuild opinions
  • MrPerfect2
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
AeroCoupe
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Thursday at 7:46 PM
JMG9350
J
