  • SN95 4.6L Mustang Tech
Gears installed
  • Thread starter Thread starter saldivo2
  • Start date Start date Feb 25, 2009
saldivo2
27
  • Feb 25, 2009
I just got my car back from having FRPP 4.10’s swapped out in my 01’ GT. I had them install a Motive bearing kit along with a Tracloc rebuild kit. Now ONLY under deceleration above 40 mph it will make a soft wirling sound coming from the rear in 5th gear and sometimes 4th. If I drop it in neutral or accelerate, everything is fine. This sound normal?
Only other mods to the drive train are a aluminum flywheel from Frodanza (if thats how its spelled) and a Centerforce DF clutch.
-Mike
trinity_gt
3,125
81
99
Canada
Feb 25, 2009
  • Feb 25, 2009
-Mike
If the bearings are all new, they're probably not set up correctly or the pinion preload is incorrect.
A
anotherstangfan
38
  • Feb 25, 2009
ive heard that the higher gear sets do generally whine or whur a little more than lower ones. maybe there is a break in period before they quite down. also check the fluid. im sure others will chime in.
saldivo2
27
  • Feb 26, 2009
I called the shop that performed the install and they want me to bring it in after I put 500 miles on it. The'll replace to the fluids and check all the spec's, backlash etc. Bad news is that won't be until April when I start driving her again...but there cool with that so we'll see
Sad to put the stang back to sleep. Damn winter
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Feb 26, 2009
  • Feb 26, 2009
500 miles isnt a lot, i would go ahead and drive it for a weekend and put the miles on it and get it fixed soon. Thats just me though.
parrish5o
Dirty South
Feb 26, 2009
  • Feb 26, 2009
A small amount of noise is normal, but not much if it was done right.
saldivo2
27
  • Feb 27, 2009
I would, except I live in NH and dont want to run it on the road anymore untill they clean all the salt and sand off. I'll take it out in the spring and see whats what.
Maybe it is normal like parrish5o said. I could just worried about nothing.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Feb 27, 2009
  • Feb 27, 2009
You should not have noise.. the pattern is off. they are going to have to recheck and adjust
trinity_gt
3,125
81
99
Canada
Feb 28, 2009
  • Feb 28, 2009
BTW, the more the car is driven with the pattern off, the less likely it is that the pattern can be corrected and the noise will go away. So when you do pull it out in the spring, make that decision quickly; don't rack up the miles hoping it'll go away or thinking you'll get back to it later.
saldivo2
27
#10
  • Mar 1, 2009
  • #10
Thanks for the replies guys. I'll drop it back off first thing in the spring. Hopefully the can correct it.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Mar 1, 2009
#11
  • Mar 1, 2009
  • #11
Mine had ZERO noise...never has even after 100K+ miles.
fast97gt
1,082
north carolina
Mar 1, 2009
#12
  • Mar 1, 2009
  • #12
i payed $375 plus the cost of the gears and bearings, guess what? i got raped, i tore everything down and redid it all again by myself. i was pissed the guy told me that it wasnt his problem, he installed what i brought him, and yes it was all brand new parts. now with almost 60,000 on the gears not a problem yet. on top of that the guys no longer in business, and good to that... p.s. i had to do it because they wine horrificly under acceleration and decceration.
tonys5.0
122
Jacksonville, FL
Mar 2, 2009
#13
  • Mar 2, 2009
  • #13
-Mike
I'm a little curious. Did you have to enlarge the holes on your pressure plate in order for the fidanza flywheel to fit?
fast97gt
1,082
north carolina
Mar 3, 2009
#14
  • Mar 3, 2009
  • #14
has nothing to with this thread, you need to pm him aor start another thread.
saldivo2
27
#15
  • Apr 3, 2009
  • #15
So I just got the car back after having the fluid replaced in the rear. They checked all the specs and said its all where it should be. Think i'll cut my loses and bring it to a local speadshop where i should have gone in the first place. I dont have any of the dial indicators or i would attempt to adjust it myself. ohh well, live and learn I guess.
Thanks for all the reply's
And to answer Tony's question if still interested, No I did not have to do anything.
squeak93
2,348
417
164
Joplin, Missouri
Apr 3, 2009
#16
  • Apr 3, 2009
  • #16
Sounds like the clutches are too tight. We are having the same exact problem with a friends 03 mach 1. Brand new carrier, carbon fiber clutch pak, new frpp 4.10 gears and it gets a whine only under deceleration. Will be taking it back apart tomorrow to see where its off. We've taken it apart twice and no luck so far. We did two rear ends that day, one was perfect and this one makes noise. It just happens sometimes. And sometimes the gears do have a bit of whine. Usually once u've driven them and they are broke it, the whine will not go away as its wore into the gears.
saldivo2
27
#17
  • Apr 13, 2009
  • #17
So I eneded up paying a performance shop in Hudson, NH who knew what the exact problem was when I described it. I was told there was no play on the pinion because the previous shop tightened it down all the way so there was no play. This then was wearing down the gear. I had them install a new 4:10 and its quiet as a mouse....Lesson learned, always go to a shop who knows rear ends. Ohh and it only took them a couple hours. Thanks for all the responses
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
Drivetrain T5-Shifting Issue (5th gear to 4th)
  • BudE_916
  • Nov 3, 2022
3K
Fox 5.0 Mustang Tech Nov 5, 2022
Mustang5L5
