  • SN95 4.6L Mustang Tech
gears on automatic with no programmer?
  • Thread starter Thread starter fswd
  • Start date Start date Mar 4, 2006
1 of 2 Next Last
fswd
  • Mar 4, 2006
I'm having new gears installed because they are going out and want to put 4.10's on my 99gt auto but don't have the money to get a programmer at the same time.. besides the speedo not being accurate, will this cause any problems? would I be able to drive or would the shift points be all screwed up? if so, is there an easier way to get around it instead of a 400$ programmer? Thanks
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 4, 2006
  • Mar 4, 2006
Shiroelex
There's nothing worse than aut
728
Westland, MI
Mar 4, 2006
  • Mar 4, 2006
I'm not too sure about the shift points myself, but I know your odometer will be rolling over more miles than you are actually putting on the car. You can get a Dallas Mustang Speedcal
for pretty cheap there, or if you haven't gotten your gears yet, get this kit.
Let us know what the difference in cruising RPMs are for you between the gears. Good luck, and 'grats on the gears!
fswd
  • Mar 4, 2006
on the bottom of the page you gave me it says:
Note: The Dallas Mustang Speedcal will only work with 1994-2004 manual transmissions and 1994-1998 automatic transmissions.
any other ideas?
Shiroelex
728
Westland, MI
Mar 4, 2006
  • Mar 4, 2006
Oh crap; I forgot about that.....
Sorry!
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 4, 2006
  • Mar 4, 2006
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=6722
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=4839
speed545
458
Montreal, canada
Mar 4, 2006
  • Mar 4, 2006
I ve always run the car with the tune in it except for a few times. I didnt notice any majors changes in the shift point set up. I will not say it doesnt make a diff but for the few meters i did with the car, i did not remark anything.
fswd
  • Mar 4, 2006
cool. thanks guys for the help and thanks for the links kilgore.. i'm just debating now if i should get one of those for the short time i won't have a programmer.. oh well i'll figure it out.. thanks
speed545
458
Montreal, canada
Mar 4, 2006
  • Mar 4, 2006
I sent you a PM fswd
Don 95Vert
1,091
Delaware, OH
Mar 4, 2006
#10
  • Mar 4, 2006
  • #10
Shift points and converter lockup WILL be way off. This is because the shifting and converter lockup are MPH based and if the MPH is off, the shift points are off. WOT shifting does have RPM trigger points, but if the MPH shift point is reached first at high TP, then the transmission shifts at whichever it hits first - and with gears, that'll be the high TP/High MPH points at WOT.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Mar 4, 2006
#11
  • Mar 4, 2006
  • #11
I agree, with a stick you can get away with out calibrating the spedo but not in a auto.
K
kuma
39
Hawaii
Mar 4, 2006
#12
  • Mar 4, 2006
  • #12
The J-Mod will help to correct for the gears by allowing the shifts to occur quicker. Shift points will be alittle better but the mph and odometer will still be off.
propellerhead
1,541
"but what's with the but shots?"
Mar 4, 2006
#13
  • Mar 4, 2006
  • #13
I wouldn't say WAY off. I have 4.10s on a 4r70w and I ran an entire week with my stock tune. The speedometer is off, but shifting is quite normal. I don't think it really calculates it on the MPH as seen by the speedometer. I believe it calculates it via the driveshaft rotation speed or something that isn't affected much by the final drive ratio.
DropTopPony
Noob Slayer
2,570
south jersey
Mar 4, 2006
#14
  • Mar 4, 2006
  • #14
I have 3.73 and an auto and NO tune or speedcal. You can get away with it for a short time being that i've driven mine like that for 5 years. My speedo is only off alittle. I did just order a speedcal.
Mike97gt
it doe snot
10,633
Mar 4, 2006
#15
  • Mar 4, 2006
  • #15
The shift points are calulated based on VSS inputs and rpm inputs. they don;t change a lot untuned but they will change. he amount o the change depends on how steep the gears are
fswd
#16
  • Mar 5, 2006
  • #16
well crap now i have two different stories.. for the guys who thinks it will drastically change: do you think it's ok to drive on for a while?
C
cronin49
Banned
Aug 12, 2003
432
SC
Mar 5, 2006
#17
  • Mar 5, 2006
  • #17
I've read in MM&FF a couple of times that this will ruin your tranny.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 5, 2006
#18
  • Mar 5, 2006
  • #18
I changed my answer
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Mar 5, 2006
#19
  • Mar 5, 2006
  • #19
you can drive around with 4.10's without problems for the most part. but i wouldn't advise it.
the car will drive fine because the shift points and torque convertor functions are programmed by MPH and throttle position for normal driving. so if the car normally shifts from 1st to 2nd at 20mph with 3.27's, it will shift at what it thinks is 20mph (actually 16mph) with the 4.10's. WOT shifts are programmed by RPM. this is a little more of a concern than normal driving shifts. with the 4R70W, there are Commanded shifts and Actual shifts. what that means is that the computer "commands" the shift at say 5000rpm but it takes the transmission about 1.5 seconds to fill up the clutches needed to make the shift. in that 1.5 seconds of time, the RPM rise another 1000rpm to 6000rpm. so even tho it's commanded at 5000rpm, the actual shift is at 6000rpm. now when you add alot of power OR change the gears, it increases how fast the RPM climb. just for reference, let's say that instead of climbing 1000RPM in that 1.5 seconds it takes to fill the clutches, it now climbs 1500rpm. your new actual shift point will be 6500rpm. you'll start banging against the rev-limiter. a new tune can lower your commanded shift from 5000rpm to 4500rpm to compensate for this. so between that and the 20% or so extra odometer mileage you'd be putting on the car, i highly recommend you get it tuned. and don't forget a tranny cooler.
speed545
458
Montreal, canada
Mar 5, 2006
#20
  • Mar 5, 2006
  • #20
This is why i lowered my 1-2 and 2-3 shift by 500RPMs. I was hitting rev limiter each time i floored it from 1st.
1 of 2 Next Last
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Monday at 5:07 PM
limp
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Rear diff rebuild opinions
  • MrPerfect2
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
AeroCoupe
2008 Mustang Bullitt stuck in Fifth gear
  • Jester67
  • Jul 15, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 27, 2026
Jester67
