  • SN95 4.6L Mustang Tech
Gears Stick When Engaging???
  • Thread starter Thread starter PioneerCrazed
  • Start date Start date May 8, 2004
P
PioneerCrazed
  • May 8, 2004
Hi all,
I'm looking into buying a Mustang, and found a 96 5-spd for fairly cheap. It says the trans. will need work. The explanation is "GEARS BEGINNING TO STICK WHEN ENGAGING."
Does anyone know what this could be, worst case scenario, about how much is it to rebuild these 5-speeds?
Thanks,
Alan
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
May 8, 2004
  • May 8, 2004
If you can do the work yourself, or know someone who will do the work for you, then you dont have to worry about the cost of "labor fees". However, if you can't do the work yourself, expect to pay about a full grand or so for a professional to drop the transmission out, rebuild it, and then re-install it.
Personally, I'de just buy a new transmission instead of rebuilding it.
twogts4us
4,188
12
79
Dunedin, FL
May 8, 2004
  • May 8, 2004
Find another Mustang...there are plenty out there. I know this is hard to do when you fall in love and get your heart all set for this one car, but look into the future a bit. Sounds like a major bill and lengthy time in the shop. Even then it may never be the same as it once was. And this may be just the proverbial tip of the iceberg.
Do yourself a favor and find another 5 spd GT and don't compromise. You'll be happier in the long run. You'll look back at the trannie challenged GT and be saying, "Thank God I didn't buy that one."
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
