  • 1994 - 1995 Specific Tech
Gears whining
  • Thread starter Thread starter King Cobra 22
  • Start date Start date May 11, 2004
K
King Cobra 22
175
  • May 11, 2004
Are new gears supposed to whine after getting them installed?
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
May 11, 2004
  • May 11, 2004
no... Should be quiet if done right.
K
King Cobra 22
175
  • May 11, 2004
What is the matter with the gears then?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
May 11, 2004
  • May 11, 2004
Not properly installed maybe they over torqued or under torqued the nut on the pinion.
1105
May 3, 2003
3,841
Daytona Bch, FL
May 11, 2004
  • May 11, 2004
They might have shimmed it wrong too... It could be a few things... Take it back to the shop and tell them to fix it for free since they f'ed it up... If they say it should be like that they are ing you
K
King Cobra 22
175
  • May 11, 2004
They will probably end up telling me "it's supposed to sound like that." or some S**t.
So I should bring it back and tell them to fix it for free? I don't think he'll do it for free though.
oh yeah do you think it could be the bearings?
1105
May 3, 2003
3,841
Daytona Bch, FL
May 11, 2004
  • May 11, 2004
Maybe not demanding for them to fix it for free... Go back and be nice about it. Say my gears are whining which is not normal, is there anything you can do to fix it? Then if they say yes, ask how much and if they give you a price... try to talk them down or out of it since its their mistake and not yours. If it was the bearings you'd probably feel a slight vibration... the whine is from an improper gear install... Something not torqued right or shimmed right. Its a PITA, trust me. Sorry to hear about what happened, hope you get it all worked out.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
May 11, 2004
  • May 11, 2004
Go back and tell them that after the install you hear a whining in the rear end. Tell them you called the manufacture and asked them if this was a normal operation for them to whine they said NO. That way you can eliminate that lame ass line “Oh that’s normal for them to whine" They probably go back and check the spec's for free. Good luck
K
King Cobra 22
175
  • May 11, 2004
Thanks man.I greatly appreciate your guys help.I am going to see him tomorow and I will let you know what happens and what he says.
SuperStang83
1,693
Boyertown, Pa
May 11, 2004
#10
  • May 11, 2004
  • #10
That's a good idea wytstang...I agree with calling the manufacturer!
Jakob
JJ95GTID
1,141
Phoenix, AZ
May 12, 2004
#11
  • May 12, 2004
  • #11
Chances are they put to thick a shim on the pinion gear. When the pinion and ring gear are too close 'tight' then you will get gear whine. So, yeah take your Stang back like everyone here has stated and do what wytstang mentioned above.
K
King Cobra 22
175
#12
  • May 21, 2004
  • #12
Well guys I finally went back to the performance shop today about the gear whine.I tried to do it earlier but either the guy wan't there or he was too busy.Well anyway he said that the gear whine is normal and that it's just a "harmonic" whine and that's normal for those brand of gears.
Also, he had a speedo gear for 4:10 gears and he installed it for me right there and said the speed should only be about 3 mph off.Well I went and tested it against my fathers car. It read 45 when I was only going 40 mph so thats 5 mph off.When we got to speeds of about 55 -60 mph I was about 10-13 mph off.Is it supposed to be that inaccurate?
I called to guy up and he left and won't be back till monday.
1105
May 3, 2003
3,841
Daytona Bch, FL
May 21, 2004
#13
  • May 21, 2004
  • #13
What kind of gears did you get? Also, the speedo seems to be right on for 4.10's. You're never going to get a perfectly accurate reading by just changing the speeds gear.
drgn5.0
603
#14
  • May 21, 2004
  • #14
what brand are they? i've heard of richmonds being prone to wine but not fms gears
K
King Cobra 22
175
#15
  • May 21, 2004
  • #15
I have 4:10 gears and yes, the brand is richmonds.
JJ95GTID
1,141
Phoenix, AZ
May 21, 2004
#16
  • May 21, 2004
  • #16
To get your speedo to correct you will need a SpeedCal from Dallas Mustang which wil correct it electronically. The only other way to correct the T5 is to swap out the internal 8 tooth gear with a 6 tooth and then use a 20 tooth external gear. This is what the '03 FRPP catalog says on page 132. If you have an automatic, FRPP does not recommend the speedo gear swap because the internal gear is machined into the tail housing. Must be a major PITA to get to it. I still don't buy the whine from the rear gears as being "normal". Hope it doesn't lock up on you. Good Luck.
H
Steering whine
  • healy1963
  • May 9, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 10, 2026
gkomo
Engine Which fan clutch ?
  • AnthonyA1234
  • Jun 22, 2026
Fox 5.0 Mustang Tech Sep 19, 2026
Mustang5L5
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
R
1999 mustang gt whining noise
  • Rlee4252
  • Jul 16, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
Mustang5L5
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
