Gears??
  • Thread starter Thread starter MUSTANGJOE
  • Start date Start date May 9, 2005
MUSTANGJOE
Silver Stanger
1,644
17
59
May 9, 2005
  • May 9, 2005
Hey guys..
me again!!, I'm installing 3.73's. My quesition is when the shop drove my car they said that My shifts are already short and that I probably already have 3.73's. We check and they are stock 3.08. Now This is my first 5-speed stang, are the shifts short stock?..meaning it hits 4-5000 rpm's quickly. And would putting 3.73's be to much?
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
May 9, 2005
  • May 9, 2005
Really depends what you want. If you want to get up to speed faster then go with the 3:73s. If you want highway miles, stay with the 3:08s. People run 3:73 and 4:10 gears all the time with the stock trans. I run a 3:35 first gear with a 3:55 rear and have no problems. I think your shop is on crack.
N8Miller
I need NOS....make it 2 of the big ones
2,661
Kingston, PA, USA
May 9, 2005
  • May 9, 2005
i think that your shop is on crack also.
if you want the best all around gear, do 3.73s. some are gonna argue that, but others will agree. like tunedin said, its about what YOU want for your car.
slow93
406
  • May 9, 2005
im running 4.10s with a five speed and first gear is almost useless. the 3.73s i think would be a good all around gear.IMO
MrKwik
1,008
Kansas City, Kansas
May 9, 2005
  • May 9, 2005
I'm also running 4:10's in one of my five speed cars. I'm shifting into third by the time I get across an intersection. I don't mind because its not a daily driver but I had one other 5 speed car with 4:10's before that was a driver and it still didnt bother my too much. Different poeple have different tolerance levels of what they will put up with for the sake of performance though. I think most poeple will say the 3.55 is the best "all around" gear for a 5-speed car but I am a big fan of deep gears so I wouldnt hesitate to run the 3.73. Now if the car is primarily a highway rig I might stick with the 3.55.
notchback
1,950
St Clair Shores MI
May 9, 2005
  • May 9, 2005
all you need to do is raise the @ss and count to what you have for sure.
3.73's is not too much
i like 4.10's
performance + 40 mpg does not exist, so decide what you want
cobradvm
245
Woodinville, WA
May 9, 2005
  • May 9, 2005
Went from 3.08s to 3.73s in a 331 stroker- debated about 3.55s for a while - was sure I was going to do these, but ended up going with 3.73s and am real glad - car really wakes up, and is alot more fun to drive.
Henceforward
The Avatar Master
485
  • May 9, 2005
I have 3.08s right now, but when I do gears I will install 3.73 FMS...
3.73s are the way to go, so I hear...
MUSTANGJOE
Silver Stanger
1,644
17
59
May 9, 2005
  • May 9, 2005
well there installing it now!..I did have stock gears. Did yours come with both bearings?..mine came with lots of bushings and 1 thing that looks like a nut! , Can I order a stock replacement bearing for these 3.73's?
txgunrunner
68
houston, tx
May 9, 2005
#10
  • May 9, 2005
  • #10
my buddies say the 373 is a good all round gear and i want to put one in but my car feels like it already has a bigger gears from stock. are the gears stamped or do you have to count the teeth to verify which gear i'm running. thanks
cobradvm
245
Woodinville, WA
May 9, 2005
#11
  • May 9, 2005
  • #11
The pinion will have the ratio stamped on the end - if you want to be 100% sure, count the teeth.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
May 9, 2005
#12
  • May 9, 2005
  • #12
Like said before, jack up the rear end and with the trans in neutral, turn the driveshaft and count how many total turns for one turn of the wheel. I too belive that shop is on crack, they should have been able to do this, they could have/lost a sale.
3.73's seem to be the ideal gear for a around town cruiser daily driver. I agree 4.10's are steep, but if you go to the track and have traction (both) they will dig you out of that hole. Some say to go 3.55's, but the truth is that they are no 3.73's and the engine revves only a few hundred rpm's lower on the highway. Once 5th is in, the rpm's between the gears is similar. Also, consider the size tire you are running, a 26" range tire is what were refering to but if your running a 28" tall tire, you might want to go a step up, and a 30" two steps.
With 3.73's and a 25.7" tall tire (275/40R17) I was shifting at 35mph, 65mph, 83mph, and about 115 is where it would top out 4th.
squeeeg
1,905
Michigan
May 9, 2005
#13
  • May 9, 2005
  • #13
I have 3.73's and 5 speed and it doesn't rev out to much. 1st gear is kindof short but you get used to that
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
