Getting electrical sensor off MAF?
  • Thread starter Thread starter Jason 302
  • Start date Start date Jun 2, 2004
Jason 302
685
71
68
Newark, Ohio
Jun 2, 2004
  • Jun 2, 2004
I plan on getting a bigger MAF sometime soon (probably the C&L 76 w/elbow) and I was wondering how to get the sensor off of the base of the stock MAF. Or does the C&L come with a new one? All the pictures doesn't show one on it. Reason I ask is because the bolts holding the sensor on are some kind of weird torx bolt with a raise right in the middle where the socket would fit down in. You know how they are. ????????? Some help guys? Thanks.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 2, 2004
  • Jun 2, 2004
A trip to the auto parts store for some tamper proof torx bits (about $6-$9) fixes your problem.
TwinTurbo93
153
Orlando
Jun 2, 2004
  • Jun 2, 2004
C&L mass air meters use stock sensors, the only thing that they change is the size of the oraface tube... the sensor is really easy to get off, you just need the right tool, take the meter with you to a parts store where they sell tools and find what you need, simple as that. Mine were just torx screws.
larrendeuce
649
Southern NJ
Jun 2, 2004
  • Jun 2, 2004
I wonder how they calibrate the meters if they use the stock electronics. I got an 80mm from a 4.2L and swapped in my electronics. I was running low 15's at the track that day, when I switched to the 80, I ran 16.2 @ 88.
P
Pop-Pops-Pony
254
Sharpsburg, MD.
Jun 2, 2004
  • Jun 2, 2004
C&L use different size sample tubes depending on the size of the injectors not the size of the Mass Air Meter...
When I got my C&L 73mm a couple years ago it came with the bit to remove the old electronics...
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
