getting hot need help
  • Thread starter Thread starter dadiesel5
  • Start date Start date Jun 30, 2007
D
dadiesel5
31
  • Jun 30, 2007
i did a h/c/i swap on my car and ever since then my car has been getting hot and i put a new t-stat, water pump, and still getting hot. can the stock radiator handle my mods or do i need a new one if so what kind do i need and where to get it i also need it to be cheap.
93 LX
3,081
Norwalk, CA.
Jun 30, 2007
  • Jun 30, 2007
new cap? I got a 3 row from the boneyard out of a MK7. Had it rodded and it has worked great in my 82 Capri with it't modded engine and stock fan.
D
dadiesel5
31
  • Jun 30, 2007
so you think i should try a new radiator cap first.
HISSIN50
34
129
Jun 30, 2007
  • Jun 30, 2007
What is 'getting hot'? If you have an aftermarket gauge, let us know what temps you see.
If you dont have a real gauge, get one before inferring anything (except the most obvious) about coolant temps.
You will need to let us know if it runs hot at speed, at idle, both, etc. Post up what the actual temps are in those conditions.
Good luck.
thumper460
3,022
Orange Park , Fl
Jun 30, 2007
  • Jun 30, 2007
HCI... maybe you did the same as a billion Ford guys be for you!! Did you know the HEAD Gaskets only go on one way?? The water flow will be stopped if the headgaskets are on wrong!! IF the gasket is on right.. there will be a square edge sticking out on the front of both heads.. and feel like nothing on the back side!! as it is curved and fits the head/block profile!! Have a Butchers!!
Just me.........................................
Thumper
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
H
Drivetrain 6R80 to t56 swap
  • Holymoses
  • Apr 25, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
AeroCoupe
