Has anyone successfully found a long-term solution for eliminating the dead-play in the accelerator on a S197? I am not talking about throttle lag (a hesitation after going WOT) or throttle hang (where the throttle plate takes a split second to close after you've released the accelerator), but rather a mechanical 1/8"-1/4" dead-play in the throttle. I can tap the gas pedal repeatedly without ever causing the RPM's to rise. It's been documented that the brushes aren't contacting the traces in the transducer until a certain point.
So far there are 3 solutions, none of which seem to be "safe" for long-term use:
1). Bending the brushes
2). Using tape + material to pre-load the pedal
3). Shifting the cover to move the brush/trace contact point
Why hasn't anyone developed a permanent fix? This dead-play makes shifting the manual rather clunky.
It forces me to constantly be focusing on how much I'm bogging the motor down with each 1st gear go, and not necessarily on the rest of my situational awareness... ie is the guy in front of me slamming on his brakes, or is the guy behind me not quite slowing down as fast as I'd like, or maybe some idiot trying to merge into my lane specifically in the spot I currently occupy!
