2001 Mustang GT with Ghetto CAI
IAT Average = 77.95115681F
IAT MAX = 88 F
IAT MIN = 64 F
2004 Mustang GT convertible with K&N FIPK
IAT Average = 89.42107564 F
IAT MAX = 128 F
IAT MIN = 66 F
MAF Average = 1662.522879 g/s
MAF MAX = 25434 g/s
MAF MIN = 485 g/s
MAF Average = 2133.267599 g/s
MAF MAX = 21843 g/s
MAF MIN = 404 g/s
[Twitch] said:As you can see, my average IAT is lower than the K&N FIPK by 16F and that my maximum IAT is much lower too. But we also notice while data logging that once the cars are moving, the IAT of both car are pretty much the same. So the only advantage I have is idle and low speeds.
Here's another interesting thing. I used a cheap knockoff cotton air filter while my friend is using genuine K&N air filter. Do you see the difference? I averaged around 1662.xx g/s of air while he averaged 2133.xx g/s whioh is much more. From the results, we can see that K&N air filter sucks in more air mass than a cheap knockoff, so there's a reason why it cost more, it's because it works better. The more air mass that is coming in, the better.
So, even though I have a lower IAT, I have less air mass coming into the engine because of the cheap knockoff air filter.
.ToplessStang said:Two points to add to this. I would think that even by just leaving the complete stock intake, you would have cooler IAT temps at idle. The snorkel on the stock intake is getting the air from the same area. Second point is about the airflow. The air flow diffrence is most likely caused by the stock plastic air intake tube that goes to the TB. It is not a very smooth flowing tube with many small restrictions. No matter how good an air filter is, it's flow capacity is limited by the rest of the intake system. Some very interesting results over all though. Oh and the other Stang was an 03
Kilgore Trout said:The fact that you gathered data from two different cars renders your data meaningless IMHO.
You need to redo your experiment using the same car for both styles of intakes.
