Give your combo and then your timing and FP
cobra dave
308
For us doing the self tuning that cant quite afford a PMS or Tweecer lets get some fuel pressure and timing settings. Try and include your current combo in detail so some of the guys can can get an idea of how things MIGHT turn out.
95 Cobra
Stage 3 non-split matched p/p cobra intake
Stage 2 p/p gt 40 heads (iron)
stock cam
FRPP 24lb. inj.
Walbro 190 lph FP
Aeromotive FPR
70mm BBK t/b
c&l 76mm Trueflow system
Densecharger Deep fenderwell CAI
MSD 6al
Billet dist.
Blaster coil
Taylor Spiro wires
Autolite 764's @ .54
BBK underdriven crank, Alt., waterpump
Fluidyne big ass radiator...........
No smog or A/C or any emissions for that matter
Timing @ 10' and FP @ 45 psi wide open
I dont think I need to get into any more motor bolt-ons suspension, exhaust, drivetrain or any of that jazz. If anyone would like to see my entire mods list I can pull it up and you can sift through the pages. Had to do it for insurance purposes.
i'm gonna post my full engine list including bolt-ons because cam, tb, injectors, dizzy, and maf are stock.
1994 GT
heavily ported Iron windsor GT 40 heads w/cobra 1.7 rr's
non EGR 5.0 Explorer upper and lower intake
bbk fuel pressure regulator
walbro 155 lph fuel pump
Holley wet nitrous kit jetted for 150 :D
bbk cold air
msd 6al
frpp wires
crane coil
march under drive pulleys
mac shorties
mac catless h pipe
flowmaster american thunder cat back
180* t-stat
no air pump and no a/c
autolite 764's @ .040
fp is 44psi wide open and timing is 8*
With THIS SETUP I was running 38-39# WOT with 21# injectors. I forget what the A/F was on the dyno, but the dyno operator at Crazy Horse said it was close enough to perfect for a street car that he wouldn't waste any time adjusting it. I've got the dyno sheet & A/F graph somewhere on disk. If I can find it, I'll post them.
Most mods in sig
Stock FPR (you can get away with them), set lash at a quarter turn past zero while running, plugs gapped @ 0.35,-4* on the cam, and timing at 16*.
Can't wait to get mine on dyno and get an AFPR but the plugs look perfect and no pre-det on the top end so I'm not to worried for right now.
Ever since I've got it running its been SOTP tuning out behind the shop (little 1/4 mile strip of dead end road) :D .
SlowGT said:
Must be nice to have enough room to get the valve covers off with the intake still on
I still have to take the upper off but since I've done a couple times now it only takes 5 min 6 bolts and a couple of turns with the screwdriver its off. :D
SlowGT said:
that's a nice setup :nice: i made 280/306 with a very similar setup in 'Old SlowGT' in my sig.
Thanks, I had some issues on that run though, I had exhaust leaks on multiple cylinders, and I think my maf was taking a crap on me. I think it wouldh have been higher with my issues fixed, but never got to dyno it after fixed, after that, threw on the maf, t/b, extender, cam, ect...(see sig) and now that I've moved, getting settled in, hopefully will have an updated dyno run.
