going carb need fuel system info
Get a holley regulator if you havent already.Then get a pick up from the tank,-08AN from the tank to the pump,then -08AN from the pump to the regulator. Use an inline filter after the pump.And from the regulator to carb,-06AN lines.
Modular2v said:
i dont remember the name of the pick up i have in my white car i will check.........what kind of power are you planning to make? natural, spray, forced induction????
on my white car i ran two pick ups with two holley blues then y'd the lines into one -8 to the regulator up front, also two inline filters at the back...........i did this so incase one pump went down on the spray i wouldnt be sweeping up parts hopefully
I made my own pick up tube using my stock one.
Modular2v said:
90 notch did u use most of the stock fuel lines leading up to the firewall ( just before the fuel rail harness)?
Yea the rubber hose is already there. I just add the 1/2 aluminum line. I ran 1/2 aluminum line from front to back. I'm running a holley blue and a mechanical carter super strip pump. I only turn the holley blue on when I'm running Nitrous.
