going from 2v to 4bl, need suggestions
65intex
85
Ft. Worth, Texas
Looking for suggestions on the best combo for intake and carb. I have a 289 that was rebuilt several years ago, nothing wild just basic refresfing of the engine components. Really like the price and looks of the Edelbrock products.
Thanks
Depends on where you want to go with the motor? Is this going to be all you will do to it? Do you want to build it up down the road with a hotter cam and heads? If you aren't going to build it up, make sure you get something that will work well with a lower rpm range. If you are going to build it up, then take that into account. I had an Edelbrock Performer RPM manifold and 600cfm carb on a motor before and after the cam/heads install, and it worked brilliantly both ways.
