Going Insane, Help!!!!!!!!!!
  • Thread starter Thread starter J90GT
  • Start date Start date Nov 22, 2005
J
J90GT
73
  • Nov 22, 2005
Im going insane crapola . I cant find out why my car will out of the blue have a huge backfire spudder and just die in the middle of the street. If i give it gas while this happens and try to keep it alive i just get smaller backfires after backfire and i just shut it off. I have to let it sit 10 mins and then it will run fine again.
Things ive done since ive owned it,which is since this problem has been occuring.
New msd 6a ignition
new msd cap/rotor/wires/coil
new plugs
new ect
new act
new o2's
new ford 24lb injectors
new #24 76mm maf
new a9L
new fuel injector harness
I even took it to the local ford speed shop and had them put it on the dyno and tune it- timing advance 14 degrees/ FP is set at 38
Pulled codes all i get is 31-85. the egr and canister are removed so nothing suprising
Can i just sum it up as a short in some god forsaken wire or am i overlooking something???? Im at my wits end, im either going to
a) blow it up
b) Sell it, but i dont wanna rip some poor bastard off
c) Rip out all the electro crap and go carb
pb_paulie_b
894
Chaptico, Maryland
Nov 22, 2005
  • Nov 22, 2005
go carb! my car was doin that when my tfi was going bad...PB
I
IntenseBlue
946
  • Nov 22, 2005
tfi module. It's the little rectangular thing on the distributor.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Nov 22, 2005
  • Nov 22, 2005
Random "dying" is usually the TFI. Don't buy the cheap-o from Autozone, try to get an Motorcraft part if you can.
HISSIN50
34
129
Nov 22, 2005
  • Nov 22, 2005
When it wont start, what are you missing? Spark, spark and injector pulsing? Etc.
Good luck.
M
myfast5oh
  • Nov 23, 2005
Next time it dies.
Next time listen for your pump. open your ignition and listen for your fuel pump. I had a problem where my ride would just buck once or twice and die, pull over and wouldn't start. Wait 5-10 minutes and fire right back up like nothing happened. Turned out to be a bad fuel pump.
I must admit the added backfire part does sound more like a TFI issue, but it doesn't hurt to listen.
Good luck.
jackchan
507
Mobile Alabama
Nov 23, 2005
  • Nov 23, 2005
sounds like a problem a buddy of mine had once. Is it running really rich??? Anyway my buddy chased this problem for over a year, had the engine rebuilt......and changed every thing anyone could possibly dream up....then it would up being a ground on the wiring harness AT the computer behind the kick panel. The screw was stripped (and not tight) so sometimes it would ground properly and others it wouldnt! Would run for sometimes hours with no problems then, for no reason just die!
trace out and make sure ALL of you wiring harness GROUNDS are grounded good and tight. This may just solve your problem.
2nd choice would be TFI module!
good luck
Jack
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Nov 23, 2005
  • Nov 23, 2005
My vote's on the TFI, as well.
rd
3,316
63
109
Ocean Springs MS
Nov 23, 2005
  • Nov 23, 2005
I vote for the tfi, and or, the computer ground. The backfiring sounds like ignition going off and then back on, at slightly the wrong time.
I just went through some of this on my 89 LX 2.3, and still have occasional stalling when cold starting.
I fried the computer trying to diagnose it.
It turned out that it was all started by a dead MAP sensor, but it did not throw that code until after I killed the puter and replaced it.
J
J90GT
73
#10
  • Nov 23, 2005
  • #10
Well, to reply to some of you guys post asking specifics.
its always on acceleration. and then bam! big backfire and the car either
A) completey dies, i pull over and IF i try to start it it'll just sputter, pop, and just wont stay on
or
b) big backfire, almost die i'd say 200 RPMS. i'll put the clutch in and try to keep it alive and its just constant small backfires which leds to bucking if i release the clutch and try to get in a parking lot etc.
I have to wait around 10 mins almost as if its just randomly flooding itself with gas then i have to let it clear out.
I thought it was a short on the fuel injector harness because the original one looked rough but i replaced it with the new injectors and didnt do anything.
So TFI would cause this? i'll buy one a new one just for ****s and giggles. and i'll try a new BAP sensor aswell but im leaning towards a short or loose ground.
Thanks for the help, i appreciate it
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Nov 23, 2005
#11
  • Nov 23, 2005
  • #11
TFI will not give off any codes when it's acting up, also remember the supplied grease must be applied to the back side of the TFI.
Black1987Stang
1,422
Jersey Shore
Dec 3, 2005
#12
  • Dec 3, 2005
  • #12
I vote for tfi or fuel pump
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
T
Fuel Looking for a little guidance
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 12, 2025
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
