Hey guys,
I'm thinking it's time to add some more power to my stang, and always wanted a supercharger. Problem is, I don't know much about them. I'm searching the forums and learning, but it's tough to know what I need for my specific setup. From what I've read, it seems like I'll want to go with bigger injectors (42 maybe?) and a bigger fuel pump (255), but other than that, I'm not so sure. I would appreciate it if you guys could take a look at my mods and let me know what I'm in for. I'm not looking to run crazy boost right off the bat, but upgradeable options are appreciated as I'm sure I'll get addicted quick. Mods are as follows...
Engine
· TFS Twisted Wedge Aluminum Heads
· Upgraded dual valve springs
· TFS 1.7 Roller Rockers
· FMS Roller Lifters
· TFS hardened push rods
· FMS E-303 Camshaft
· Bosch 24 lb/hr. fuel injectors
· 190 lph In-tank Fuel Pump
· FMS Adjustable Fuel Regulator
· Cobra Intake Manifold
· Moroso Cold Air Intake
· Pro-M 75mm Mass Air Meter
· 65mm FMS Throttle body
· FMS Underdrive pullies
· Edelbrock High-Flow water pump
· JMS Custom Programmed Chip (3 program settings)
· High Output Alternator
· MSD-6AL ignition
· MSD Billet Distributor
· MSD 8.5mm Spark Plug Wires
· MSD High Output Ignition Coil
Exhaust
· BBK 1 5/8” Unequal length ceramic coated shorty headers
· 2 ½” Off-Road H-Pipe (still have stock H-pipe)
· 2 ½” Flowmaster 2 chamber Cat-Back
Miscellaneous
· Kenny Brown welded subframe connectors
· 3.55 Rear-end gears
· Pro-5.0 shifter
· Energy Suspension Polyurethane Motor/Trans Mounts
· Centerforce Dual-Friction Street/Strip Clutch
· Dynoed 290 rwhp/311 ft-lbs
Engine
· MSD-6AL ignition
Exhaust
Miscellaneous
· Pro-5.0 shifter
