Good deal on a T5?
69Rcode_Mach1
1,473
Salt Lake City, Utah
Hey guys i am planning on buying a t5 in the future and have just been browsing. I have found what seems to be a good deal. I plan on buying one and then rebuilding it. Ronstang is helping me build up my car and said to wait till later. But i came across this and i can't get a hold of him right now. It came out of a 1989 GT Mustang and includes bellhousing and hurst shifter. Here is the item description
"Transmission out of an 1989 mustang gt. 100k miles. Grinds into second gear at high rpm. Perfect besides that, quiet in all gears, shifts well. It was replaced by a tremec. It is completely drivable and ready to install. Comes with a hurst short throw shifter without the handle. It works very well. includes bellhousing."
100$ reserve.
But if you look at my sig i will be cranking out a lot of power and will also be throwing in 3.50 gears when im done with engine. I know that my engine will walk all over this tranny stock, and i want to know if i should jump on this offer right now or wait and save up and buy one of those strengthened t5's. I will rebuild this one myself and build it up if i can, but thats why ive come to you guys. The trannys over all appearance isn't that bad, but you can't just go off of that. Its not a necessity but this seems like a steal and if so i figured ill pay and let it sit in the garage as i rebuild it slowly and build my engine. What do you guys think??
if you rebuild it using gforce parts or something you will be ok. If you rebuild it stock and shift hard or power shift it will eventually fall apart on you if you plan on making over say 350 lb/ft. $100 doesnt sound like a bad deal though, I paid a little more then that for mine and it basically does the same thing when I shift into second but couldnt afford the rebuild right now so I just drive it around ;).
I believe that the '90 and up T5's are rated at 300 ft/lbs so you might want to try to find one of those.
The '89 could be upgraded, but I'd try to find one of the later ones anyway. I just rebuilt a T5 out of an '86 GT although I did change to the '90 and up cluster gear as well as new 2nd and 3rd gears to upgrade mine to 300 ft/lbs.
On my T5, my "clutching teeth" or "dog teeth" on the side of second gear looked terrible. I bought another second gear as I didn't want to risk putting that thing back in there.
The main teeth on second gear looked good, it was those clutching teeth on the side of the gear that were pitted, concave, and just looked terrible.
Anyway, my T5 came off of ebay, and I was told mine grinded going into second and after seeing the side teeth of the gear I knew why!
I wouldn't take the chance of buying another T5 that grinded. Those rebuild kits do not include gears and gears cost around $65 a piece.
I was under the impression that worn synchros could be replaced with just a rebuild kit. Well it's true that they can be replaced, but when the "clutching teeth" on the side of the gear are considered part of the synchro, you have to buy the gear as well if they are bad.
Perhaps the '89 T5 will not need a new 2nd gear as it's clutching teeth may still be OK, but I wouldn't want to take that chance.
Anyway, my advice is to get a '90 or up that doesn't grind.
Randall
im running about a 325hp 302 in a fox i found a 4clyinder t5 for free so put it in, lasted about a week found another for $50 rebuilt it and i lasted for a year. my problem wasnt synchros, i broke gears
Thanks a lot guys. Sorry to disappear my internet stopped working yesterday. Yeah i agree with you all. These are things that ronstang said too. He recommends getting one of those built ones. I will be cranking out close to 400-450fwhp and 450-500 ft/lbs of torque when im done with my motor so i need a tranny that can survive that. The tranny is not going to be abused maybe powershifted from time to time for fun very rarely. I need something that can reliably handle that power and not break on me. The car will be a daily driver not a strip hero. so i need something that will lst me 100K miles before a rebuild or so. Any suggestions on remanufactured trannys, or cheaper routes like rebuilding it myself. My car stock is putting out more than 320 ft/lbs of torque right now. so it will eat througha stock t5.
My $0.02 worth...
The moment I saw your by line with "351" I knew the T5 is not the tranny for you. I know, its a good deal...but a good deal isn't a good deal if its not what you need.
Specifications on the latest WC T5 are 330 ft-lbs torque. Your 351w puts that out at every firm launch. The T5 will last about 5 minutes under this punishment.
Now could you make do with it? Sure but you'd be babying around your fast ride and never being able to put your foot in the carb.
What you need is a Tremec TKO or 3550 transmission. This is a better fit for your existing '69 bell housing. It simply needs a spacer plate (not an adapter plate like the T5 needs). Look at www.moderndriveline.com and read the tech articles there. Call those guys up and let them know your plans. They give good advice even if you don't use them.
Do it right the first time and save yourself the grief that comes along with thinking you're out of the woods only to find you need to spend $1000 more and you have a car thats sitting parked in the garage.
Jeff
