jwalker
cajunscrew said:SHHHH, just don't tell her. I tried the timing trick, but was afraid to screw it up. Exactly which screw do you loosen to turn th distcap. Is it the two tiny screws on the inside middle, or the screws along the outer edge inside the lower cap?
There is 1 screw at the base of the distributor (where it goes into the block( that you need to loosen. It uses a 1/2 wrench. You will need a timing light.
