GOOD SET-UPS...
  • Thread starter Thread starter 6FIVE_STANG
  • Start date Start date Jul 20, 2006
1 of 2 Next Last
6FIVE_STANG
142
San Jose, CA
Jul 20, 2006
  • Jul 20, 2006
Ok, right now I have a 289 with a EDEL. perfomer intake and a HOLLEY 570CFM carb.
I plan to change the intake to either a performer RPM or AIR GAP(not sure which is better?)
Nows my question is what is a good cam to match and what else do i need to buy to match this set-up? (is this a good start?)
-NOTE: daily driver looking to get 350HP+
_THANKS!_
Max Power
1,774
St Paul
Jul 20, 2006
  • Jul 20, 2006
If you want even a prayer of getting close to 350 horsepower, you will need aftermarket heads.
washMO66
1,000
Washington, MO
Jul 20, 2006
  • Jul 20, 2006
+1 - The heads
6FIVE_STANG
142
San Jose, CA
Jul 20, 2006
  • Jul 20, 2006
Yeh I know. Im planing on getting some TRICK FLOWS or GT-40X in a few months.
But can i do that after i do a few mods or should I buy that first?
6FIVE_STANG
142
San Jose, CA
Jul 20, 2006
  • Jul 20, 2006
Im only 17 and have little knowledge about my car.
For right now i was going to buy:
-Intake
-Air Cleaner
-Cam
-Alternator
-Ignition System
Am I in the right track?
Shakin66
628
Waycross, Ga / Lake James, NC
Jul 20, 2006
  • Jul 20, 2006
Theres nothing wrong with being young, at times I wish I could go back in time myself. If I were you I would look into all of those parts you mentioned but dont do what I did in my youth and spend $ on the engine without changing the rear gears to a more agressive ratio 3:25-3:70. I finally changed that and the car was turned into a beast in one afternoon.
6FIVE_STANG
142
San Jose, CA
Jul 20, 2006
  • Jul 20, 2006
Ok, what should I start upgrading first to last?
jerry S
1,365
52.22N 5.12E
Jul 20, 2006
  • Jul 20, 2006
the GT-40X heads are not even in the same league as the Trick Flows. Get the AFR 165s if you can.
In terms of your last question, in what order should you proceed, you will need to replace the
1. Heads
2. Cam
3. Intake
in order to take full advantage of the power gains you will see. It will cost you more money to do this 2 or 3 times compared to all at once. So save your money and wait. Heed the lesson of the parable of the young bull and the old bull (from the movie colors)
The young bull and old bull are out strolling together when they see a herd of cows. The young bull says to the old bull,
"Why don't we run down this hill and f**k us one of them cows?" to which the old bull rhetorically asked;
"why don't we just walk down and f**k all of them?"
Get the picture?
Before settling on the heads, you have to be sure of your pistons. Did the PO swap them out? You see, if you put new heads on thinking you will get a 10:1 CR but instead, you have a 8:1 CR because your pistons are not what you think they are, you are screwed. You will have spent lots of money and gotten yourself a dog in return.
Get a cam matched to your head flow. The flow data is out there so cam selection is not such a big secret anymore. Make sure that you make your power in a range that the crank can sustain and the valve springs can take. Guys that tell you to get Edelbrock Victor parts where the power band is between 4-8000 rpm are full of stuff and nonsense. With a 289, look for a cam that makes its power between 1500-6500. Get a cam that is within spec for the lift on the valve springs (.550 of lift for AFRs for example, which is a hefty cam) on your new heads.
I like the AIR Gap over the Performer.
jS
6FIVE_STANG
142
San Jose, CA
Jul 20, 2006
  • Jul 20, 2006
so my best bet is to save up about 5,000 and build the motor....
better start working overtime!
jerry S
1,365
52.22N 5.12E
Jul 20, 2006
#10
  • Jul 20, 2006
  • #10
$5 large is pretty high unless your labor rates are high
$1400 for AFR heads
$200 air gap intake
$200 cam shaft
According to my math, that is $1800 in parts. I think the labor to install all of the above would be about 10 hours. At $50 an hour, that is $500, for about $2500 out the door after sales tax and what not.
If this 289 has a bottom end that is about 40 years old, you might consider freshening that up. You are only as strong as your weakest link and 40 year old main bearings ain't exactly the Rock of Gibraltar.
D
D.Hearne
11,730
south louisiana
Jul 20, 2006
#11
  • Jul 20, 2006
  • #11
You don't HAVE to change the cam and heads to see gains. Sure, it would be nice, but at your age, you'll likely never get the money saved to do it all at once, unless you're exceptionally disapplined. Do what you can afford now, the intake. As you have the money, you can do a cam swap later, the only thing you'll be buying twice is intake gaskets, those aren't going to break you. And later, you can do heads again there,(if you ever get the money saved at your age ) you'll be buying intake gaskets again, and again a third set isn't going to break the bank, intake gaskets don't cost THAT much. I may be 47 years old, but I still remember how tough it was when I was a teenager to get just the money to do a 4 bbl swap, and that was with used parts. Either of the RPM's will still net you some oompf! on the top end over the Performer, even with the stock heads and cam. If you really want to save, buy a used RPM intake. That's what I usually do, intakes rarely ever wear out. I think the last new intake I bought ( a big block RPM for a 390) I turned around and resold it in favor of a used factory 428PI intake. Even the Ford A321 I have on my Ranger was bought second hand, but still new in the box. Just don't buy a used flat tappet cam. Shop for a nice set of used heads if and when you get the money. Everyone touts the AFR's but any aftermarket heads will net you a gain for the money. I was going for a set of Brodix heads when I ran across the Canfields I have now. The Canfields are the equal of AFR165's, & I bought em new in the box, but again, second hand off Ebay for $1100. You'll also need to remember to have the money for roller rockers, screw in studs (if the heads don't have em already) and new pushrods to go with the heads, so plan on another $300-350 extra for that when you shop for heads.
57fairlane
560
Oakwood, GA
Jul 20, 2006
#12
  • Jul 20, 2006
  • #12
If you are going to mess with the motor at all, get the best heads YOU can afford.
If its a budget-builder, find a set of E7TE heads and learn to port them. Carbide bits are roughy $15-20 a piece or the $50 set through summit. If you don't have an air compressor you might want to make friends with someone who does. After you feel comfortable, move on to the 289 heads.
At this point, the next step up is a set of 69 or 70 351 heads or GT-40 irons. You probably wouldn't want to port these without consulting a head porter in your area.
Then you start getting into aluminum heads. Cheapo ebay ones run $800 assembled while decent AFRs/Twisted Wedge/Canfields run $1000 and up.
For 350 fwhp, you will need ported heads.
The better the head, the more mild a cam you can run.
Something like a 218/224 on a 110 would probably put you where you want to be with ported stock heads/ Performer RPM etc . . .
3.55s, h-pipe, decent muffler . . .
For cheap you could get 260 rwhp with a stick no problem.
iskwezm
4,159
20
79
Rowland Heights,California
Jul 20, 2006
#13
  • Jul 20, 2006
  • #13
on my ol' 289 I had a 270* cam with .484 lift and a Performer manifold/650 CFM carb and .060 "stock" block. It put out 305 RWHP. I was amazed as well as the guy that runs the dyno, but then i got greedy and put some RPM heads and bigger cam and lost HP.
66Runt
680
Jul 20, 2006
#14
  • Jul 20, 2006
  • #14
Just a thought
If you are going to take the intake off anyways, a head gasket kit from Rockauto.com wouldn't be that much. If you can get your hands on a die grinder, and do some thorough research, you *could* do a port match and maybe even clean up the exhaust a little bit. Heck, there is enough good write ups on the internet with pictures, that you could actually do a lot more than a "little clean up" with some patience and attention to detail.
So now you've got a set of better breathing stock heads to go with the cam and the intake. That would get you by until you can buy some nice heads. And don't get caught up on name brands either. there are some darned good heads out there cheaper than AFR's and Trick Flows.
Anyways, just a thought. Good luck,
Scott
D
D.Hearne
11,730
south louisiana
Jul 20, 2006
#15
  • Jul 20, 2006
  • #15
I did a set of E7's (two sets now) The first set, while I can't give you hard numbers, I'm sure work far better than they were. All I did to these was open up the exhaust ports on the sides and roof to match a header gasket, then expanded and blended the passages into the bowls under the valve. I left the floor's as is, other than polishing with a sander roll. The opening up included removing the thermactor bumps in the roof. With good bits, all this can be done in less than an hour per head. I also polished the chambers, also removing the sharp corners to eliminate hot spots. The intake sides, I pretty much left alone, other than removing casting flash or any other sharp edges. Also gasket matched them. All this doesn't take a professional to do it, just a steady hand and common sense. After the grinding and polishing I had the local machineshop do a valve job and the seats were finished with a Serdi machine.
jerry S
1,365
52.22N 5.12E
Jul 21, 2006
#16
  • Jul 21, 2006
  • #16
I think he HAS to change the heads and cam if he wants to see his stated aim of getting 350 HP.
D
D.Hearne
11,730
south louisiana
Jul 21, 2006
#17
  • Jul 21, 2006
  • #17
But you keep forgetting he's a teenager with shallow pockets. What he wants and can afford are two very different things.
jerry S
1,365
52.22N 5.12E
Jul 21, 2006
#18
  • Jul 21, 2006
  • #18
When I was 17 back in 1984, my brother and I bought a new ski boat for $8000, 50/50. We wanted it.
$4000 back then is a lot more than $4000 now, that's for sure. I worked my ass off to pay for that boat. If he wants 350 hp, he can afford it. He just has to work for it.
D
D.Hearne
11,730
south louisiana
Jul 21, 2006
#19
  • Jul 21, 2006
  • #19
Oh, I agree, but I also recall the other "wants" of a teenager as well that tend to bleed off cash. $4000 may not be a lot of money to some, and to me it's still a chunk of change and hard to save that kind of money on a limited income. he can do it piece meal and not break the bank doing his own work. Like I said before, the only parts he'll have to buy more than once are gaskets. And doing things more than once is good experience at his age.
blascrw
191
Opelika, AL
Jul 21, 2006
#20
  • Jul 21, 2006
  • #20
heads
While I agree with the heads...I have some input...
I am no expert so this is my .02
granted he will not get 350 this way...
but I say consider leaving the heads unless you have the money to do the whole engine...
if you change to a newer head aftermerket of Ford you WILL loose compression.
The chamber size of the early head is smaller than any head I think produced now.
having said that you can get different pistons and increase compression...
http://www.mustangsandmore.com/ubb/Forum12/HTML/012253.html
Read this: http://mustangsandmore.com/ubb/BudgetSmallBlock.html
and this: http://www.mustangmonthly.com/howto/26821/index.html
and this: http://www.mustangmonthly.com/techarticles/39446/
and this: http://www.mustangandfords.com/techarticles/mufp_0506_budgets/
There is another site..cant find it now... a subscription site has lots of good info...
I rebuilt my first v8 when I was 13...
It can be done, and can be done on a budget...
Plan PLan Plan
Make sure you think of the parts together working as a whole...
Big AFR heads will do you more harm than good unless you take careful consideration...
Find a local track...find a guy who has been racing a while...running vintage iron...a roller block is a different beast and reacts differently to different mods.
make sure you also consider the "streetability" of the car... a 350hp at the wheels is not exactly a street friendly car for a teenager...
Plus alot of these mods will REQUIRE you use premium fuel. and you will not get good gas mileage...also something to consider...
just my .02
lastly I cannot stress it is a package...you must plan for it as a package...
If you really want to spend 5k...consider crate engine...has a warranty...Mustangs unlimited 5.0 GT40x 345HP crate 3200.00 still money left...
Ron
1 of 2 Next Last
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
C
Bored with my 73
  • Curtis Harper
  • Apr 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 23, 2026
RaggedGT
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
