I am going to be putting a Trick Flow stage 2 camshaft in my car, and I was wondering what the best after-market valve spring kit to go with is. The car is a 94 cobra so it has the Crane 1.7 rockers stock, therefore, the TFS cam will be around .580 lift. I know the stock AFR 165 springs are only rated at .550 lift and even then I've heard that is questionable.
PTV clearance will not be an issue because the car will have KB dome pistons. I am looking for a valve spring kit that can just be installed without machining the head. Any help or advice would be appreciated, thanks.
