got 1100$ what first??
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
ok i sold my old stang today, i got a grand total of 1100$ : 8/
ok my plans for my roller motor (which will dropped in after its built) are....
edel performer manifold (going carb with this motor)
holley 600 cfm carb
thumper heads
E, B or TFS stage 1 cam(need help deciding)
no ac, no smog
underdrive pullies
thats for the motor
now what i could do to my car now is
4.10 or 3.73 gears
2-2500 stall
semi manual valve body
tranny cooler
what should i spend my money on first? the car or the motor, i was considering getting thumpers heads now so i can get the big hump out of the way.( or should i get some cheaper gt40 irons to save money??) or spend it on gears and drivetrain.
or i was thinking, building the motor, keep same drivetrain, when i drop the motor in i want to see how much of an improvement i get then do the drivetrain. because if i do all this at once i wont be able to tell what is gear and what is motor.
any suggestions?!?!?
As far as what's first....that's a tough call. Personally i went after my drivetrain before anything else, since a stock 5.0 is pretty fun as it is, and it's not hard to destroy a stock T5. Other than that, i would start with subframes, gears and a good shifter. Oh, and do yourself a favor AND save a little cash, and buy a Wieand Stealth instead of the Edel intake...you won't regret it!
Ok i missed the part about your car being an auto...in that case i'd go for a shift kit if you don't have one, and a stall with some 4.10 gears.
N8Miller said:
gears and stall converter would be done first with a nice shift kit if it was me....
I concur...to add I would go with 4.10 gear since it an AOD...depending on which cam you choose from your list...you will need a TQ converter of 3000RPM advertised duration to hit your 2000-2500 actual RPM stall speed...
