Got a decent mph at the track last night
classic boost
709
canton, oh
last night was 'no track prep tuesday'.
with no boost controller, 15psi (which i only see at the end of high gear- 12psi most of the run) i ran a [email protected] 1.63, [email protected] 1.67, 10.28@137 1.61.
last pass i hooked the controller back up which give me 19psi thru most of the run. since the boost came in so quick, i blew the tires off. 10.23@143.7!! 1.74.
all shifts were @ 6,000, going thru the traps @ 6,000. it was running really lean for some reason last night, and i melted a plug on the last pass. the car seemed to be running good, though.
on a side note: i had to make the 60 mile trip home in the rain with hoosier 'don't drive these on the road or you'll die' drag radials. :shock:
Congrats on the new mph Paul!! Get that thing off the line and run 9's all day long. I know you realize it but you've got LOTS left in that 60 foot.
Oh, and that is a decent mph. lol
how did you manage the drive on those slicks (sorry DR)? I thought you couldn't even move in the wet with those. "Nature's burnout box" HA. It takes balls to click off solid 10s and drive it 60 miles to/from the track. You didn't bring spare tires?
they do have 2 grooves. lol. they are brand new, so that helped, but i went 40mph and had to pull over and stop ALOT. wet roads didn't give me a problem, but running water did. it was a lonnng ride home.
i've driven 2hrs to race before. it's a street car, so i race it at the track in the same trim i drive it around on.
i upgraded the 65 amp 14 years ago (i don't even remember to what).
the alt was only charging 12.9 under load (hi-beams & fan).
made a pass missing badly at 11.00. connected a portable battery jumper to the batt while i made the next pass- 10.57 breaking up less. charged the batt and the jumper- 10.25 breaking up in high gear only. replaced the alt with a gm 94a 3-wire. charges under load at 14.2 and the miss is completely gone.
I cheat a little, my track tires ride in the back seat. 45 miles to the nearest 1/8 mile and 110 miles to the 1/4 mile track. I don't worry too much yet, but when I get a turbo on I will worry a little about my home built trans and rearend.
Does the track give you a hard time about that mph? I wish we had E85 around here. I may mix my own. One of the tracks around here sells ethanol for $110 a drum so it would be cheaper than 87 octane.
