- Mar 30, 2005
- 472
- 0
- 0
Stang8URMPRT said:Dont use that gasket either... Just use silicone on it. The factory uses silicone, and that's what you should use.![]()
why not use it?!?!?Stang8URMPRT said:Uhhh.. the rear cover gasket you have laying there. Don't use it.
Like I said.. Use Silicone... Gaskets will leak... Ford does NOT use a gasket from the factory, they use Silicone. Mine has 99K on it, and no leaks.. and the rear plate is not leaking yet. Use silicone.. not the gasket.bobbys9350 said:why not use it?!?!?
Not how it's done from the factory... But if you want to use the gasket, go for it. When it leaks... don't start a thread saying "Rear end leaks! What should I do??" lolbobbys9350 said:how bout the gasket with silicone?
bobbys9350 said:its not gonna leak if i use a gasket plus silicone, lol
bobbys9350 said:a;;right dude. im only 15 and still learning. ok? i figuired i would just go the full mile and get 31 and then could run slicks down the road once i get my tranny done and NEVER have to worry abotu breaking anything...
