Granada Disc swap alignment specs
Ok I did a search and most of what I saw was listed for the 65-66 cars. I am assuming that the alignment specs would be the same for radials for those years as new years (67) specifically. Can anybody tell me if the specs listed below are correct for use with the Granada swap. If not what year Granada should be used for the specs?
Caster: +1.5° to +2.5°
Camber: 0 to -.5°
Toe: 1/8" in total
Those look right but...
Go to www.opentracker.com
he has a spec page on there, and I double checked with John verbally on my granada setup on my 65 and the numbers on the website are good.
Do your homework when selecting an alignment shop, make sure they do old school stuff, I got REAMED trying to get mine aligned last time.
Those specs. will work. One issue is to make sure the caster and camber are the same on both sides, or at least within .2deg. of each other.
My daily driver has:
0 - Camber on both sides
2deg. positive caster on both sides
1/8" toe in
Also, do not let them set the car for road crown.
Edit - My car has the Granada swap too with no bump steer kit and it drives great.
