Granada front disc, Explorer rear disc - what Master Cylinder
  • Thread starter Thread starter 68keyblr
  • Start date Start date Nov 19, 2007
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Nov 19, 2007
  • Nov 19, 2007
I finished up the installation of the Explorer rear end so now I have 4 wheel power disc brakes (and 3.73 tracloc )
What Master Cylinder will work with my setup?
Pbum5
515
Minneapolis, MN
Nov 19, 2007
  • Nov 19, 2007
I used a Mustang SVO (84) Aluminum MC on my 4-wheel disc setup.
Cheap (under $30) Aluminum (light)
You have to make new brake lines to the distribution block because the outlets are on the opposite side as the stock MC and you will need a proportioning valve. I used a Willwood adjustable.
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Nov 19, 2007
  • Nov 19, 2007
Thanks, that's perfect!
Pbum5
515
Minneapolis, MN
Nov 19, 2007
  • Nov 19, 2007
While at the parts store be sure to get the proper adapter fittings for that SVO MC to fit the standard size brake line.
66Coupe289POWER
81
Raleigh, NC
Nov 20, 2007
  • Nov 20, 2007
Do you have any pics of the Explorer rear installed? I was thinking of doing this to my 66 but have heard of driveshaft issues b/c the pinion is offset??? Thanks
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Nov 20, 2007
  • Nov 20, 2007
I'll get some pics this weekend. I had the pinion moved back to center. It's not really that bad of a swap, just a lot of little stuff you have to do.
I'm working on a writeup that I'll post.
The Explorer rear end is so much beefier than the 8" that was in there, and the 3.73's sure are fun . Disc brakes a are nice benefit too.
ultrastang
1,092
Arkansas
Nov 22, 2007
  • Nov 22, 2007
Correct size MC line fittings for Mk VII/SVO MC are 9/16"-18 and 7/16"-24. If you can get the correct sized fittings locally, that would be better than using adapters.
If you can't locate the correct line fittings locally, I have them available through my website.
http://www.ultrastang.com/Ultrainfo.asp?Page_ID=21
H
HHStang
566
Coastal SC
Nov 22, 2007
  • Nov 22, 2007
Mopar master
I like the Mopar truck master that is pretty popular with the hot rod set. It uses regular flares and SAE fittings.
I have this exact set up (w Granada rears) on my '72.
Mike
Decurion
353
Livonia, MI
Nov 22, 2007
  • Nov 22, 2007
How about a 78 Granada manual disk master? Also cheap, and plentiful, if not as light as the SVO unit.
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Nov 22, 2007
#10
  • Nov 22, 2007
  • #10
Mike
What year/model truck do I need to ask for?
H
HHStang
566
Coastal SC
Nov 23, 2007
#11
  • Nov 23, 2007
  • #11
mid 80's
seems like Mid 80's??? Let me know and I'll post a picture later. It's aluminum with a fairly large black reservoir with outlets on the inner fender side (away from engine).
rbohm
6,698
550
204
tucson,az
Nov 23, 2007
#12
  • Nov 23, 2007
  • #12
dont forget that he needs a disc/disc master cylinder, not a disc/drum mc.
CarFreakGT
20+ Year Stangneter
May 26, 2003
395
11
29
Louisville, KY
Nov 23, 2007
#13
  • Nov 23, 2007
  • #13
Please do, and let us know when you put it up. This is one of the options that I'm considering for the rear when I get my front finished. Looking forward to it!
68 manual disc/drum master cylinder
  • Butchd88
  • May 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2026
Butchd88
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
