I've read that if i do the granada disk-brake swap, my old rims may not fit around the new wheel hubs, question, how can I tell if this will be the case before I go out and spend the money to do the swap?
skywalker said:I've read that if i do the granada disk-brake swap, my old rims may not fit around the new wheel hubs, question, how can I tell if this will be the case before I go out and spend the money to do the swap?
68rustang said:what car do you have, and what wheels are you talking about?
chepsk8 said:I'm not sure, but it's not much, maybe 10-20 thousands needs to be turned off the hub or wheel. Anybody done this?
66 BLAKE 96 said:I just talked to my buddy, and he said that he didn't remember a specific number, but he did remember that it was quite a bit. More than a few thousandths anyway. I'd just measure and give it a shot.
For the record, his 65 has logged quite a few miles over 7 or 8 years, and he's had no problems with the swap.
chepsk8 said:I've got the Granada hubs on chepie, here's the deal:
The bearing hub is larger than all 65-70 wheel openings. the only wheels that fit no problem are the Magnums. Other wheels can be modified by slightly enlarging the center hole, or machining the hub smaller. Later wheels and aftermarket rims should be fine. for Chepie, I have early Keystone 14" wheels which look like torque-thrusts, and they fit fine. My spare rim came from the Granada donor car.
As for caliper clearance, the 65-67 styled steel wheels are tight with the caliper, as Blake sez. Later styled wheels clear the caliper no prob.
Look VERY VERY VERY similar!!! The spokes on mine are definitely painted (don't know if they came that way or? either or I like their look), and they are 14".chepsk8 said:Looks like the wheels I have on Chepie! Are they 14" Keystones? If so, they fit with no mods needed.
