I just bought a Granatelli 90mm MAF, and ever since I installed it I cant get my car to idle. Ive tried resetting the timing to about 15 degrees and setting the idle up to about 800 rpm and then resetting the tps at .98, and then it will idle pretty good, but when I shut the car off and then start it again I have the same idle problems. I'm not really sure on what to do at this point cuz I dont have a lot of knowledge with efi systems so i need some help with this one. I also bought FMS injectors which I have not installed yet and someone told me that it would probably fix the idle problem after I install them. My engine is pretty much stock except for a mild cam and its bored .30 over and I have installed a cold air intake. If anyone can help, PLEASE DO! Thanks in advance.
