After the Thumper heads Im done for a while!! 80mm,,,,yeah???giddyup306 said:I think summit sells them. You'd probably be fine with an 80 especially if you plan on doing more upgrades. Just don't get a huge throttle body.
Nope after this Im donegiddyup306 said:If your like 99.99% of all mustang owners there will be more upgrades![]()
So which one,,77,,or 80mm??65mm,,stock intakejb89coupe said:Pro M manufactures the units to Granatelli specs, they just rebrand them. As for your whistling accufab - what size tb and what intake? When I had my 70mm accufab on my stock intake (63mm port) it whistled at part throttle. When I put the performer on (70mm port) it stopped.
willys1 said:65mm,,stock intake
First things first,,I need a maf... Is the 77mm shorty any longer or shorter then the Bullet??jb89coupe said:That may be your whistle. If you plan on keeping the stock intake you may want to open it to a 65mm gasket.
And I'm happy with my pro m bullet, only issue was some difficulty getting the cold air kit on around it (it's longer than the stock meter housing). I'm not sure what the difference is between the pro m/granatelli specs, just make sure you get one calibrated for your injectors and intake tract (stock/conical/cold air) and you should be fine.
willys1 said:First things first,,I need a maf... Is the 77mm shorty any longer or shorter then the Bullet??
I have a Dense Air Charger fenderwell unit!! I guess that means I have to go with a bullet,,,Ill call and ask I guess.Highbredcloud said:GET a Pro-M...I would go with the 80mm since it is cheaper....than the 77mm...it is plastic, however, and not aluminum like the 77mm...look on eBay for best deals on both the 77mm and 80mm...I have 2 77mm and I have no complaints...they make them both in a shorty style and a regular style...both take a conicle filter
willys1 said:I called up Summit and Jegs,,they dont carry pro M,,only Granatelll.Pro M makes them,,they are one in the same.But they cant tell me why Granatelll is 30 bucks more then pro m![]()
willys1 said:I hate when my threads die
Demolet automotive,,he makes the dense air charger cai.,,He usaully sells them for 179,,but being Im a past customer he let it go for 169!! And he said he will set it up for his system(I have his CAI) how Im not sure.jb89coupe said:Did a question go unanswered? Just out of curiosity where did you find that pro m for $170?
Really,,,He said you can notice a difference in the summer when its hot.I cant tell because its the only one I had besides stock.BUT I do notice a difference in the real, real cold weather,my stang runs like a raped apejb89coupe said:That's a good price. I had a densecharger for a while but traded it for a mac cai. Everything else under my hood is polished aluminum/chrome, so the black plastic kinda looked out of place. fwiw I noticed no performance differences between the two systems.
