D Dave14 Founding Member Sep 18, 2002 193 0 0 Calgary, Canada Mar 29, 2004 #1 Mar 29, 2004 #1 I have a 1996 mustang GT and when I shift fast from 1st to 2nd it grinds. It does not grind when i shift slowly. Is there anything to do to fix this? Thanks
70stangcoupe Founding Member Nov 12, 2001 2,895 0 0 Winston-Salem, NC Mar 29, 2004 #2 Mar 29, 2004 #2 I'm sure you're a good driver, but just to cover the basics... Are you sure the clutch is all the way in? Are you letting it out too early or trying to shift before the the pedal is all the way down? You probably need new synchros in 2nd.
Blakers01GT Master of the Clubhead Founding Member Sep 21, 2001 2,110 0 0 Brown Deer, WI Mar 29, 2004 #3 Mar 29, 2004 #3 70stangcoupe said: I'm sure you're a good driver, but just to cover the basics... Are you sure the clutch is all the way in? Are you letting it out too early or trying to shift before the the pedal is all the way down? You probably need new synchros in 2nd. Click to expand... how much would that be?
O okc2KGT New Member Oct 27, 2003 91 0 0 Oklahoma City Mar 29, 2004 #4 Mar 29, 2004 #4 2nd gear synchros are around 300 bucks the last time i checked, 3rd is way cheaper
D Dave14 Founding Member Sep 18, 2002 193 0 0 Calgary, Canada Mar 29, 2004 #5 Mar 29, 2004 #5 I shift with the clutch all the way in, even if i hold the clutch in then throw it into second, it still grinds. Thanks for the replies so far.
