  • 1994 - 1995 Specific Tech
Grinding 5th
  • Thread starter Thread starter Guero
  • Start date Start date Oct 29, 2005
Guero
2,148
Oct 29, 2005
  • Oct 29, 2005
Well i noticed today when i shift into 5th it grinds not all the times sometimes. What could be wrong? Hopefully its the shifter.
Blackened302
1,439
South TX
Oct 29, 2005
  • Oct 29, 2005
hmm, if i grind, it's always 3rd. it doesn't happen when i take my going going into 3rd, though. might wanna try going into 5 slowly.
Guero
2,148
Oct 29, 2005
  • Oct 29, 2005
i forgot to mention that, if i go into it slowly it wont, but then i forget and i put it in normal or a little fast and it does grind.
M
madams74
664
Maryville, TN
Oct 29, 2005
  • Oct 29, 2005
Mine does the same and I have 99. It went away for a few months, now its is back. I have to ease it into 5th slowly.
H
hurt
173
San Antonio, TX
Oct 29, 2005
  • Oct 29, 2005
What shifter are you guys using? When I replaced my trans a few months ago I threw in a mgw with it. After that mine grinds when going in fifth. Didn't before with stock shifter/trans.
Guero
2,148
Oct 29, 2005
  • Oct 29, 2005
stock shifter.
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
Oct 29, 2005
  • Oct 29, 2005
i'm pretty sure 5th gear doesn't have a synchro (thats what somebody told me)
Mine did it for a while when i had my MGW in, now w/ the stocker it never grinds
C
cmozez
450
Tupelo,Mississippi
Oct 30, 2005
  • Oct 30, 2005
Mine does it also. I have a pro 5.0 but it was in for 2 years before the 5th gear grinding started. Does 5th have a syncro or not. I am going to have to pull my tranny to replace the TO bearing and was going to replace the syncro.
super302
May 29, 2004
2,878
Davenport, IA
Oct 30, 2005
  • Oct 30, 2005
no T5's or T45's had 5th gear or reverse synchros, the 3650s (01+) are fully synchro'd
C
cmozez
450
Tupelo,Mississippi
Oct 30, 2005
#10
  • Oct 30, 2005
  • #10
So what can cause the grinding? I have an adjustable clutch quad, can that be the problem? Is it the clutch ? I plan on replacing the clutch anyway but I am really confused now.
OrangeMustangGt
1,976
Cape Cod, MA
Oct 30, 2005
#11
  • Oct 30, 2005
  • #11
actually im sure that the t-5 in our cars has syncho's, i had replaced it when i did my rebuild. also, thats classic symptoms of a worn synchro. If it is, it will get worse, grind, then pop out of 5th eventually. Just be to be sure tho, check your clutch, make sure its dis-engauging al the way
HISSIN50
34
129
Oct 30, 2005
#12
  • Oct 30, 2005
  • #12
Cobra spec T5's have a blocker on Reverse. Others have reported seeing a blocker on reverse in other T5's - I think they might have had [aftermarket] HD WC T5's, which often incorporate aspects of the CObra and Z-spec box.
5th gear should have a synchro. You guys would know if you didnt. OD often uses a soft synchro though (like bronze, instead of fiber).
super302
May 29, 2004
2,878
Davenport, IA
Oct 30, 2005
#13
  • Oct 30, 2005
  • #13
oh, someone on SVTP told me they didn't have 5th gear synchro's.....bastards
xr8d302
I bought a 27" monitor to compensate for my lack o
Apr 29, 2004
1,113
Medicine Hat, AB
Oct 30, 2005
#14
  • Oct 30, 2005
  • #14
This is all interesting, I've NEVER heard of a 5th gear grind....I've always just eased it into 5th for the simple fact that if I have to shift quickly to my last gear, I've already lost the race
divit250r
314
Columbia City, IN
Oct 30, 2005
#15
  • Oct 30, 2005
  • #15
You might check the fluid level. My cousin replaced the 1-2 blocker ring and input bearing in his, but didn't get enough fluid in it. It ground 5th for a week or so before he filled it up, and now it does it every time.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
