  • SN95 4.6L Mustang Tech
Grinding Noise.. Brakes??
  • Thread starter Thread starter XxMustang281xX
  • Start date Start date Jun 10, 2013
XxMustang281xX
194
Everett, PA
Jun 10, 2013
  • Jun 10, 2013
i have a 99 GT and it recently started making a grinding noise in the rear passenger side wheel. it sounds like my brakes, like metal on metal, but it does it ALL the time. not just when im on the brakes. it does it non stop. would this be the brakes?? why would it do it constantly though?? i dont want to buy new brake pads if thats not what it is..
trinity_gt
3,125
81
99
Canada
Jun 10, 2013
  • Jun 10, 2013
Pull the wheel and inspect the pads.
Disc brake pads may have some degree of contact with the rotors. If the pads are down to the metal you could hear noise even without touching the pedal.
While that side is in the air and before you've pulled the wheel, give it a spin. Check for roughness or looseness in the wheel indicating a possible failed wheel bearing.
joshjwc9
1,095
17
39
Palm Harbor, FL
Jun 12, 2013
  • Jun 12, 2013
Slide pins? Check the pads like Trinity said, if one pad is drasticly more worn your calipers are not truly floating and riding on that pad. Take them suckers and lube 'em like on prom night.
XxMustang281xX
194
Everett, PA
Jun 15, 2013
  • Jun 15, 2013
thats exactly whats happening. i took it to the garage and they said my one rear caliper is bad, and that the brake pad on one side was worn down to nothing and the other one had no wear hardly at all. so do i need to get a new caliper? i definitely need new rotors and pads. whats the best deal on rotors and pads and possibly calipers? are these kits any good?
http://www.ebay.com/itm/FRONT-REAR-...stang|Submodel:GT&hash=item5aefd80e24&vxp=mtr
http://www.ebay.com/itm/FRONT-REAR-...stang|Submodel:GT&hash=item4162413653&vxp=mtr
joshjwc9
1,095
17
39
Palm Harbor, FL
Jun 15, 2013
  • Jun 15, 2013
I've ran brakemotive rotors before. And loved them. They performed great with even some Hawk HP+ track pads (although this wore out the rotors because of the pad compound. I hear some great things from R1 Concepts too.
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
AeroCoupe
CHANGING BRAKE PADS
  • Scwhitten
  • Jun 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 12, 2026
nickyb
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
