  • 1994 - 1995 Specific Tech
GRINDING SLIGHTLY...help!
  • Thread starter Thread starter 91LX_5L
  • Start date Start date Feb 26, 2004
91LX_5L
1,943
British Columbia
Feb 26, 2004
  • Feb 26, 2004
When I shift into 2nd fairly fast (mostly when its cold IE very first shift) it tends to make a grinding noise, but the noise seems to be comming from the shifter its pretty quiet, not a loud grind like people get when they dont know how to drive.
I got a steeda tri-ax...think the stops need to be adjusted?
I also have a VERY VERY slow leak (more of a bleed) on my tranny, think mabye my fluids are a bit low and once my tranny warms up it has no problem? 90% of the time it only does it when its cold and I shift fairly fast, and its my 1st shift 90% of the time too.
So what do u guys think it is, tranny fluids or stops on my shifter or somthign else?
WOULD it be the stops on my shifter? is it worth my time to pull it apart and see, its quite a bit of work since I got that stupid gold plate put back on.
Eric94GTvert
596
PA, Nazareth
Feb 26, 2004
  • Feb 26, 2004
I would say it is the tri-ax itself or any aftermarket shifter. The stock shifter uses rubber bushings to damper the sounds of the tranny. They are the same bushings thats makes it shift sloppy. When you remove the stock shifter, you get the grinding. I have it with my Pro 5.0. and I had it with my tri-ax on my other car. You can live with it or put the stocker back in.
91LX_5L
1,943
British Columbia
Feb 27, 2004
  • Feb 27, 2004
I had a tri-ax in my last car, its LOUDER yes makes a noise plus u can hear whining from tranny BUT its not supposed to make the griding sound when you shift, it barely does it but just wondering if you guys think its the stops or the fluid? im gonna change my fluid anyways to senthetic.
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Feb 27, 2004
  • Feb 27, 2004
with my blue thunder shifter i hear a noise like gears in a blower. lately however i hear a rattling type noise when i put the petal to the floor, are talking about the same thing?
91LX_5L
1,943
British Columbia
Feb 27, 2004
  • Feb 27, 2004
yeah it sounds like a turbo/supercharger thats normal, thast not the sound I mean, I mean a actual GRINDING sound like when you shift with no clutch haha but not nearly as loud and only comming from the shifter area.
mytight95
2,605
Dothan,Al
Feb 27, 2004
  • Feb 27, 2004
you prob. need to just replace the fluid, i would recommend the synchromesh from gm, more heat dissipation, and also slightly thicker than atf but a little slicker due to its synthetic makeup
if this doesnt do it i would replace the blocker rings (first-second0
jason
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Today at 4:46 AM
Mindseye007
F
5R55S Torque Converter Grinding while seating
  • feloniusgru
  • Mar 2, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 2, 2026
ctandc
C
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
