grinds in 5th
FoxRod87
243
Carolina
I have recently put a rebuilt 2.95 wc t-5 in from astro performance. the first time I put it in. It would grind going into 5th. so I shipped it back and he said he didn't see any problem but he said he put a new syncro in. so I got it back and it was fine until I got on it and tried to shift it into 5th fast. and it grinded really bad. and has done so ever since. just have to shift slow. I was woundering if I could put some gear oil in it or if there was something else I could do.
foxrod, sorry about your misfortune, but i've heard of new t5's grinding into 5th a couple times before
be thankful it's not into second, and why are you shifting into overdrive fast anyway?
The 2.95 first gear T5's all used ATF in them. If you are having problems, I would try a drain & refill with a top grade synthetic ATF. Gear oil is definitely not the best choice for your model T5.
