Ground Clearance on 95 GT
DMacRacer
28
Anyone know the ground clearence from the bottom of the rocker panel to the ground? I'm trying to verify if My NEW TO ME 95 GT has been lowered. Or any other way of measuring? If it has been lowered, I have read that, if the rear shocks are to be replaced use the Fox Bodies because they are shorter. Is this true?
Thanks
Take a looksie at the springs. You might be able to see a part number (for instance, I recently checked to see that I can still see the Eibach part numbers on my rear coils).
I'd have to check rocker height, but it's low (I drive up on a 2x4 before getting what is otherwise a pretty low jack under the car). These cars sit like Jeeps with stock springs - it's real easy to tell if you have stock springs.
Good luck.
