GT 40 HEADS
  • Thread starter Thread starter pancho55
  • Start date Start date Dec 20, 2004
P
pancho55
Houston, Tx
Dec 20, 2004
  • Dec 20, 2004
Thinking of putting som e original cobra GT40 heads on my '68 mustang w\302. THese are originals not knowk off p heads. Heard their might be some plug clearance issues and header issues. Does anybody have any experience with this?
D
D.Hearne
11,730
south louisiana
Dec 20, 2004
  • Dec 20, 2004
No clearance issues with those GT40's. Only with the "P" heads is there a problem.
D
D.Hearne
11,730
south louisiana
Dec 20, 2004
  • Dec 20, 2004
But before bolting them on, check your piston comp height and if they're dished. You wouldn't want to lower the comp ratio in doing the swap. The Cobra GT40 heads ( the one's that actually came on the Cobra Stangs) had 62 cc chambers. The 68 302's had either 54 cc ( J code) or 58 cc heads. You'd need to run flat top pistons with the cobra heads with as close to zero deck height as possible. Milling the Cobra heads isn't recommended either as Ford milled them from the start at the factory, then again by an outside contractor before they were assembled on the motors.
P
pancho55
Houston, Tx
Dec 20, 2004
  • Dec 20, 2004
GT40 heads
Thanks, these have been ported and polished and I am not sure of the specs on it. I am taking them to a machine shop to get them cleaned and Magna Fluxed. Will keep every body informed of how it goes. These are going on with a performer inatake and a 600 cfm carb.
D
D.Hearne
11,730
south louisiana
Dec 20, 2004
  • Dec 20, 2004
Performer or Performer RPM? They'd work better with the RPM
DarkBuddha
2,215
Seattle & Tampa
Dec 20, 2004
  • Dec 20, 2004
Do you mean original as in Ford late model GT40 heads like from Cobra Mustangs, or do you mean original as in '60s vintage GT40 heads? If they are vintage, they might be worth some cash to the right people...
P
pancho55
Houston, Tx
Dec 20, 2004
  • Dec 20, 2004
GT40
Late model Cobra cast number F1ZEE.
DarkBuddha
2,215
Seattle & Tampa
Dec 20, 2004
  • Dec 20, 2004
Not worth the coin vintage heads bring, but still damn good heads, especially for the money.
Good luck!
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
1997 Mustang GT Overheating Issue
  • Mustang1988!!
  • Sep 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
