GT-40 Heads
racinjason89
Can anyone explain to me the difference between the explorer GT-40 heads, and the aluminum ones? (other than the obvious)I have a chance to buy a complete explorer motor, cheap, but don't want to be stuck with it.
The Ford aluminum heads have bigger valves and ports compared to the iron versions.I really like my FRPP Y303 aluminum heads;they have modest sized ports that respond well to porting and make good street friendly power.Good low end torque and good power up to about 5400 rpm after which they lose ground to most other aluminum heads.If you are primarily a quarter mile thrasher then you may want to get heads with bigger ports and valves.I don't care for the FRPP X heads which I considered.They have bigger ports but don't flow better than my ported Y's. I also like the AFR165's,maybe the best of both worlds;very good flow through relatively small ports.
