Gt-40 intake help!
  • Thread starter Thread starter fastfordguy
  • Start date Start date Oct 9, 2005
F
fastfordguy
33
  • Oct 9, 2005
i just got a upper and lower gt-40 intake off a 96 explorer ,my question is what all do i need to install it? i know i need gaskets. but will all the vacumes lines from my stock intake connect to it and will my stock 5.0 tb fit onto it? i didnt get the explorer tb. anything else i should know about installing it?
And how much does the gt-40 intake in HP? should it be ported? i see it on jegs for almost 600 $ so im assuming it adds a bit.
i might go back and get the gt-40 heads from explorer ,are they good?
95GTV8
386
Washington State
Oct 9, 2005
  • Oct 9, 2005
ummm hp wise, should be about 10-15 stock, but it all adds up once you add more mods, and yes gt-40 heads are good, aluminum heads are better, but for the budget minded gt-40's are great, all your stock vacuum lines will work fine, good luck on the install!
bubba-dough
1,044
Indiana
Oct 9, 2005
  • Oct 9, 2005
I am running the Explorer that has been ported on my 347. I think its fine for those of us on a budget. You will have to drill the ACT sensor. The bung is there but not drilled, no big deal though. Also there are a couple of vacuum ports on the explorer that you will need to cap. Your tb will work on it. The explorer tb is slightly different and will only work with some mods, I think tmoss or maybe someone else has showed how to do it.
BTW if you are running the stock heads and you can get the gt40's at a good price go on and get em and change everything at once. Good luck.
F
fastfordguy
33
  • Oct 9, 2005
intake
yeah im gunna get the heads soon and a cam soon, the intakes were 20.00 at a local u pull it parts place on sale. im thinking about getting the gt-40s or ordering some of those thumper ported e-7's ,i am on a budget.
thanks for the advise and stuff all
F
fastfordguy
33
  • Oct 9, 2005
delete
delete
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Oct 9, 2005
  • Oct 9, 2005
bubba-dough said:
The explorer tb is slightly different and will only work with some mods, I think tmoss or maybe someone else has showed how to do it....
Directions are in the "tech" section of my website...........in my sig.............
F
fastfordguy
33
  • Oct 10, 2005
thanks
thanks for the reply ,ill check out your site.
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
  • Mindseye007
  • Aug 16, 2026
Mindseye007
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Engine Explorer - Lower intake internal cleaning
  • R82148V
  • Nov 11, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Dec 6, 2025
rednotch
