18mustangs
VibrantRedGT said:Actually you can trick it. I made an EGR delete kit. Capped the header (5/8 flare nut at Lowes), capped the elbow (cut a peice of aluminum) and h-pipe. Hacked off the piping on the smog ports going into the back of the heads. Used JB weld to block the piping holes and bolted them back onto the heads. Lastly I removed the base of the EGR itself and plugged the hole on the shaft. Plugged the EGR back in the harness and tucked it away. It's been this way for 5 years and I've never had a "check engine" light or anything smog related ever.
You may "trick" the CEL from not illuminating, but unless you turn the EGR function off in the computer it's still adding lots of timing at part throttle which will create to a lean condition which may cause detonation. A few years ago I "deleted" EGR with the Flare nut method (my LT headers didn't have the EGR bung) and did not got a CEL, but my car pinged like crazy at part throttle under load. I hooked up the Fox EGR when I did the Fox TB conversion and the ping stopped. Just because you don't hear it ping doesn't mean it's not, even mild inaudible pinging is bad for the engine.Tim
