- Nov 12, 2005
- 13
- 0
- 0
i just installed a gt40 manifold upper and lower with a 75mm TB. everything is good, idle is perfect, but i hear whistling. i checked all the vacuum hoses and gaskets.. the ones that need to be connected are all connected. the ones that arent are sealed perfectly. i even put silicon sealant on the threads. theres no way air is getting in. i sprayed carb choke cleaner around and no bogging or bubbles. still once the engine warms up, the manifold whistles loudly on idle. the manifold was ported out alot from the previous owner. could it be just that since the manifold is aluminum the porting made it whistle? i dont know. has anyone had a similar problem??
i would suggest going back to the stock tb.
