GT-40p heads on a 86?
What cam would be best suited for this setup? it would be with a explorer intake setup, no smog. I think i may have read somewhere that a B303 would work?
On the other hand, i also heard something about valve relief?
Valve reliefs - Hah, some guy on theturboforums bought a valve and glued an abrasive disk to it and trimmed the excess. He put the valve in the head, bolted it down, put a drill on the valve stem and went to work.
Voila, homemade valve reliefs, lolz.
I would reuse the OEM 86 cam. It's no slouch (it had to make up for those crappy OEM heads) and it already sounds mean. That should also alleviate any clearance problems you might otherwise have though you SHOULD still clay it up to be certain (honestly, for that combo... I'd bolt it on and rotate by hand... if eveything is good then press on with pride).
If you put those heads on an '86 shortblock without properly checking clearance, you might at well have a good backup plan because you will almost certainly grenade it. Stop fiddle dicking around with those archaic junk iron boat anchors and just buy a set of Twisted Wedges. T-dubbs are practically guaranteed to clear and you'll actually be able to run a decent cam instead of that letter cam garbage.
Lemme tell you how I really feel... Haha.
I've actually seen that method done a few different ways with success. If you keep the grit from getting down into the engine and you don't botch up the valve seat/guide, it seems to make perfect sense to me... :shrug:
Had a buddy do something similar. He actually cut a notch into a spare valve he had laying around. Turned it into sort of a "blade" I guess? Took his time, added a lot of WD40 to the guide while he cut. Worked pretty well.
