- Feb 11, 2009
- 245
- 2
- 19
Hi there guys, wanted to see what you thought about a car im buying and what HP ratings you think will be produced.
MOTOR
302-.30 over
8:1 compression
Hastings rings .17 top, .15 bottom
Tall Ford Racing valve covers-black
Edelbrock Performer RPM aluminum heads
7/16 head studs w/ 1/2 spacers
Ford Motorsports 1:6 aluminum roller rocker arms
Hardened push rods
BBK long tube headr and H-pipe
Mac flow path 2 & 1/2" mufflers
Comp roller cam
30 lb. injectors
Mac gear drive timing
ProFlow mass air meter
70mm throttle body
Ford idle air adjuster spacer
Milodon 7-quart oil pan with windage tray
GT-40 lower intake w/ Car tech upper (extruded/honed)
High volume oil pump w/ hardened drive shaft
ProCharger P600 9-14 psi w/ 2-core intercooler
MSD 6 boost timing master ignition
MSD Blaster TFI coil
BBK adjustable fuel pressure regulator
1901ph fuel pump
Potima battery
140 amp alternator
16 inch electric fan pulling/14 inch electric fam pushing
AFCO 2-core aluminum radiator
DRIVE TRAIN:
Adjustable clutch cable and quadrant
Tremec TKO tranny
Ram clutch
8.8 rear end (Strang 3.73 gears)
5-lug disc brake conversion
Guages:
200 mph white face gauges
AutMeter monster tach w/ shift light
2/16 boost gauge
2 & 5/8 mechanical fuel pressure gauge
2 & 1/16 air/fuel ratio gauge
Dual gauge pod on A-pillar
Chassis:
8-point rollcage
Cross bar subframe connectors
Factory 5 lower and upper control arms
Lower Wild Rides battle boxes
Sallen strut tower brace
17 x 9.5 rims
205/40R17 front tires
275/40R17 street drage radials
Thats the Build Give your input Please.....
MOTOR
302-.30 over
8:1 compression
Hardened push rods
Comp roller cam
30 lb. injectors
70mm throttle body
1901ph fuel pump
Potima battery
140 amp alternator
DRIVE TRAIN:
Tremec TKO tranny
Ram clutch
Guages:
2/16 boost gauge
Chassis:
8-point rollcage
17 x 9.5 rims
This car does exist. Do you think its a good built engine??????????????
