  • SN95 4.6L Mustang Tech
GT Factory HP
  • Thread starter Thread starter 98blackmagic
  • Start date Start date Jun 8, 2005
  • 3
First Prev 2 of 3 Next Last
stangliter04
185
Port St John, Florida
Jun 9, 2005
#21
  • Jun 9, 2005
  • #21
My stock dyno numbers
226hp 268tq
that was with nothing at all done to the car/3000 miles on it.
17% drive train loss should have put me at 217hp
300bhp/ton
530
England
Jun 9, 2005
#22
  • Jun 9, 2005
  • #22
98blackmagic said:
I wanted to see if anybody else ever noticed this, I just did last night. The 99-04 GT PI cars are rated from the factory at 260hp, but if you look at all the mustang mags they allways get around 215 at the wheels for a automatic and 230 or a hair more for the 5 speeds. In the april 2004 issue of Muscle mustang and FF they compared the GT, March1, and cobra ( this is what I was looking at when I realised this) they dynoed the GT and got 214hp and 265lb of torque, now with a 23% loss thru the automatic that would put it at 280hp not the 260 ford rates them at. If you look thru the mags for the articles the stock 5 speed cars usually make around 230, and with a 15% loss this would be around 280 also. It is a known fact that the cobra's were underrated from the factory, so am I doing something wrong on my calculator or are the GT's a little underrated too?
Yes you are!
Engine power output is a massive topic, I have posted several responses before so if you wish to do a search on my username feel free to do so.
Basically there is no said amount that is being lost from the drivetrain, all cars vary, even cars of the same make and model will not necessarily loose the same amount.
There are also several areas where descipancy occurs.
1. Ford rate the engine in the GT at 260bhp SAE Net. However there are many types of bhp. But they don't all carry the same value, the same as $1 US dollar has a different moneytary value to $1 Australian dollar, yet they are both still dollars.
-PS
-HP
-BHP
-Imperial
-Metric
These all cause different numbers to be produced. So depending on WHICH scale of bhp a rolling road dyno is measuring will vary what the numbers are.
2. The standard of how bhp is rated SAE stands for the Society of Automotive Engineers and have many standards which concern temp, humidity and which ancillaries are on the engine (there are many other standards used across the world, which means cars form other countries with the same bhp claim may be producing more or less than an American car rated under SAE standards). As a rolling road dyno will be done at ambiant temps in a work shop or outside there is no control over other influencial factors which could cause an engine to produce more/less power. There are correction calculations which can be used, but are not always and they are not always used correctly when implemented.
All in all this will cause a variance in recorded numbers.
3. Accuracy of the rolling road dyno. As most of these will be used all day every day it is safe to assume that they are not 100% fully calibrated all of the time, because it would be expensive and time consuming to do so every day. If you except that any rolling road dyno pull could be +- 5-10% it makes it a lot easier to understand why cars produce such a wide variance of numbers.
4. How the power of the engine is measured. A rolling road dyno measure the rotational force at the rear wheels, so even tyre pressure and tread pattern can and do affect outputs. More importantly is how a measurment is acheived, torque is usually measured as a rotaional force against a counter weight this is then calculated to give a HP reading according to what engine rpms are. But there are other ways of measuring HP, originally I believe it was how fast a Horse could pull a weight of X amount vertically via a pulley over a set distance. Hence the name Horse Power.
In addition to these factors there are different claims on how power is lost via the drivetrain. If you increase the HP of car via a power adder like NOS you are not changig anything in the g/box, axels and so on. The drivetrain remains constant so should it suddenly be using more power to rotate the same components? Well yes to an extent because if there is a greater force acting on it then the amount of friction will also have incrased, but the 15% rule does not cater for this, e.g.
A car dyno's at 220rwhp if we then / .85 (for 15% loss) = 259bhp.
Drivetrain loss = 39bhp
If that same car now dyno'd 420rwhp. / .85 = 494bhp
Drivetrain loss = 74bhp
Is the drivetrain really taking almost double the HP the rotate it even with out any changes? I doubt it.
It should be requiring more power but the % loss should be less, for argumants sake say the 420rwhp car only lost 10% (420 / .90 = 467bhp), this would mean a 47bhp loss from the dirvetrain, much more realistic. Although it does mean your crank BHP is lower than you may are wished for. However wishing will not defeat physics any more than hope can.
And because of this there are quite a few engine builders out there that will claim any Mustang GT 4.6 with a manual gearbox will loose about 30-40bhp thru drive train loss, except it exceptional circumstances. So a rolling road dyno of 230rwhp corrected to SAE Net standards plus 30bhp for the drivetrain loss would funnily enough equal the magic figure of 260BHP.
I doubt that the GT's are underatted, there will always be a few that produce that bit more power, but this will be due to manufacturing tolorancies. All of the should be producing 260bhp if they where put on an engine dyno and rated as per the standards.
This also applies to the 03/4 Cobra's.
The Cobra's are one hell of a car and rank high on my list in my fantasy garage, but if they ALL really produced over 400BHP SAE Net I'm sure Ford would have advertised the fact, for two reasons:
1. The Cobra is Fords premier performance model in the US (forget the GT, but that didn't exist then and is a totally different league), so there was no higher end car to steal sales away from in the Ford group, unlike GM they deliberatly underated the Fbody's so as not to over shadow the Corvette with the same engine, it was of course a lot cheaper to purly'Advertise' a lower BHP than actually go to the expense of detuning the units or building specific spec units just for the Fbody. Very clever in all reality.
2. The Corvette Z06 had 405BHP SAE Net, and although slightly more expensive could well be considered as an alternative to the Cobra, so it would have been beneficial for Ford to advertise the highest BHP but they didn't they advertised less than the Vette which again would indicate that the engine did only produce 390BHP SAE Net.
Personally I dont' believe the Cobra's are underatted, or not by much anyhow because they just arn't fast enough to carry bigger statistics.
If tested on a like for like basis by the same driver under the same conditions an 03 Cobra will put down almost identical 0-60mph and 0-100mph times as a manual C5 Corvette.
The Vette has 345bhp SAE Net compared to the Cobra's 390bhp SAE Net but the Cobra weighs more.
The Vette weighs i at about 1456kg so that = 345 / 1.456 = 234bhp per metric tonne power to weight.
A 03 Cobra weighs in at about 1650kg, 390 / 1.650 = 236bhp per metric tonne power to weight ratio.
Almost identical, only 2hp in it!
The big thig the Cobra has is HOW it produces the power, as it is FI it produces more power and specifically torque than the Corvette for more of the time. LS1 is a great motor but doesn't have the low and even mid range grunt of engines of old. The blown 4.6 will be producing more power from low down.
So remeber PEAK power outputs are pretty meaningless, its the profile of the graphs that are important.
And only ever take dyno numbers with a pinch of salt because they are anything but accurate.
BlackenedSVT
1,841
New Jersey
Jun 9, 2005
#23
  • Jun 9, 2005
  • #23
GREAT POST
SilverGTV8
295
West Brookfield, MA
Jun 9, 2005
#24
  • Jun 9, 2005
  • #24
226hp 268tq
Same numbers i got with the same milage on the clock.
02LaserRed2V
379
Augusta, GA
Jun 9, 2005
#25
  • Jun 9, 2005
  • #25
My auto put down 205hp/238tq when stock. Underrated, I think not.
Then again, the dyno, climate, and other factors can be the reason for my usually low and pathetic #'s.
machfelon
52
New Jersey
Jun 9, 2005
#26
  • Jun 9, 2005
  • #26
wms004 said:
Hahaha. was that at the Disneyland dyno?.. Either that or ford played a nice trick on you.
C
cronin49
Banned
Aug 12, 2003
432
SC
Jun 9, 2005
#27
  • Jun 9, 2005
  • #27
Kilgore Trout said:
My GT is bone stock and it dynos at 301RWHP
BULL****.
C
crazykid2056
Banned
Apr 27, 2005
46
#28
  • Jun 9, 2005
  • #28
Perhaps the LS1 didn;t have anough low end to compete with a 502ci. However, the LS1 has enough down low and mid range to outrun most anything today.
98blackmagic
386
wouldnt you like to know
Jun 9, 2005
#29
  • Jun 9, 2005
  • #29
thanks for everybodys input, (300bhp/ton) you just did a entire teaching lesson in your last post I was doing my math wrong I guess. It's a little more complex than I thought.
Jackie Chan
I didn't read this.
2,507
Orlando, FL
Jun 9, 2005
#30
  • Jun 9, 2005
  • #30
if you really want to know, pull your engine and put it on an engine dyno.....
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Jun 9, 2005
#31
  • Jun 9, 2005
  • #31
i think Ford is little conservitive on their HP figure, ever since the 99 Cobra fiasco.
FYI, my car recently span the dyno at 240.8hp/281.6ft-lb with side exhaust, and mid pipe.
with 15% drive train power loss, that would come to 283.3hp at the crank
tomustang
Psychotic Member
3,434
McLean Hospital
Jun 9, 2005
#32
  • Jun 9, 2005
  • #32
300bhp/ton=too much time on your hands.
good post
E
escudolm
22
#33
  • Jun 9, 2005
  • #33
My 03 auto. GT dynoed 237rwhp and 280rwtq with nothing but a prochamber and a catback. I was very happy that day.
J
jimfitzgerald
6,672
#34
  • Jun 9, 2005
  • #34
260 X .80 = 208 rwhp for automatic
260 X .85 = 221 rwhp for 5 speed
These are advertised numbers. That means EVERY Mustang GT needs to make these numbers. Since there is always a little variation from car to car (bell shaped curve, you know), the average Mustang needs to make more than these numbers. A very small percentage will make significantly more. It all depends on the variability and standard deviation, etc. So, yes, they will under-rate them a little because of the slightly weaker ones.
twogts4us
4,188
12
79
Dunedin, FL
Jun 9, 2005
#35
  • Jun 9, 2005
  • #35
Do you really believe there is that much variance in these mass-manufactured mod motors? I'm not doubting you Jim...I'm just trying to understand where much variance would come from...sloppy cam timing? How much variance are we talking about here?
hotmustang331
2,967
Bastrop,TX
Jun 9, 2005
#36
  • Jun 9, 2005
  • #36
Well its funny, there REALLY is no % of drivetrain loss, its determined by which trans you have and stays about right there no matter how much power you make, excluding WAY up there power lvs as the extra stress will cause more loss. They proved it in an 5.0...made like 180RWHP or something and using the 15% it had 30HP or so of loss...then they sprayed the nitrous and used the same 15% but due to the increased the power it said that it lost more like 45 HP through a drivetrain that had not changed. Thus proving that % is flawed, or so they say. Supposedly its about 30HP for most 5spds...puts the 99+ GTs right on par.
J
jimfitzgerald
6,672
#37
  • Jun 9, 2005
  • #37
The 15 and 20 percent are just average numbers used to estimate the hp loss through the drive train.
J
jimfitzgerald
6,672
#38
  • Jun 9, 2005
  • #38
I have no idea. I just know there is aways a little variation. I suppose it is relatively small.
Maza4ever14
187
Bay Area, CA
Jun 10, 2005
#39
  • Jun 10, 2005
  • #39
i dynoed my stock auto o4 gt and it came out to 214 rwhp with 254 rwtq on a dyno jet.
i would scan my sheet but i dont have a scanner
big T
265
Hawaii, oahu
Jun 10, 2005
#40
  • Jun 10, 2005
  • #40
Does a tqr cnvtr help hspwr #'s or hurts them. Im not the biggest fan of dynos, but thats all we have to est. our #'s, unless u run it on the track and guess from that. Ive heard that steep gears and converters can hurt the dyno #'s even though I made 243rwhp/284rwtq with my current set up. My car feels alot faster than that, but I contribute the feel to the added gears/convtr.
  • 3
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
C
Progress Thread 2004 Comp Orange GT
  • ctandc
  • Jun 26, 2023
  • 2 3
5K
1996 - 2004 SN95 Mustang -General/Talk- Yesterday at 1:53 PM
ctandc
C
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
J
2000 GT Auto Vortech V2 questions
  • jhooks
  • Jan 3, 2022
1996 - 2004 SN95 Mustang -General/Talk- Jan 3, 2022
COramprat
W
Bought a 2006 GT Convertible 5-Speed
  • WVOHVANCFL
  • Mar 4, 2021
  • The Welcome Wagon
The Welcome Wagon Mar 5, 2021
General karthief
