GT to LX tail light swap
CHRISSOLES
20
CALIFORNIA
so i have a 1989 gt with the origanal tail lights on it. i want to replace them with the lx tail lights. but i dont exactly no what all i would need to get or do. if any one could tell my what all i need to buy and how i would swap em i would much apreacaite it thank you.
You need to take out the rear plastic panels to access the lights as if you were to change a bulb, then its just a matter of a couple of nuts on the back of each light assembly to remove and install LX one. It should be quick and easy replacement. Bulb housings should fit.
Either or. Depends on what you buy.
you can either buy the entire lens...new from aftermarket, or you can buy lens used.
or you can buy used entire housings.
Your choice
