There are several difference between the regulars 40s and the Ps.
I know that the exhaust valve on the Ps is smaller than the one on the 40s.
Stock Ps have a 1.46" exhaust valve.
The spark plug angle has been changed to provide better combustion. This is the reason why they make P specific headers. Instead of being on such a sharp angle like E7s and regular 40s the spark plug on a P head comes out of the head much straighter. This can cause interference with a stock header primary.
P heads are not drilled for the thermactor piping at the back of the head. So techincally they are not smog legal on Fox mustang.. The crossover tube will bolt up but there are no holes in the back of the head for the air pump to introduce air to the exhaust as it exits the combustion chamber.
I believe that the P heads also have a smaller combustion chamber which should raise the compression ratio a bit. Not sure how much smaller though.
I am sure that there is more but that is all that I have.
I have a set of P heads on my 93. Pretty good budget head. If you have to put a bunch of money into them I would save for a good set of aluminums I have a bout $350 wrapped up in the heads including buying them and putting new valve springs on.
